Frustrating Problem With Front Driver Marker/Turn Signal Light
Old Oct 7, 2008
mapdel02's Avatar
mapdel02 is an unknown quantity at this point
Exclamation Frustrating Problem With Front Driver Marker/Turn Signal Light
OK so I just noticed this problem a couple of days ago but when I turn on my marker lights on my car my drivers side marker light will not turn on. however this is the light which is also my front turn signal. the turn signal works without fail. now I have done some searching on civic forums and google and found that the turn signal has its own fuse. therefore I checked all the "light" fuses under my steering column and all are fine. can anyone shed more light on this issue I am stumped... This is a 2002 honda civic LX. Thanks for all your help.
Cheers,
M-A
Old Oct 7, 2008
Re: Frustrating Problem With Front Driver Marker/Turn Signal Light
do the other parking lights work? fyi, the front marker/signal bulb has TWO filaments in it which is how the bulb works as both. so it could just be that the park filament is burnt out and the signal one is still good. if all the other park lights come on, i would replace the bulb first. then if still nothing, its something wrong with the parking light power wire going to the bulb.
Old Oct 7, 2008
mapdel02's Avatar
thanks. that does make quite a bit of sense.
Poopies
Apr 20, 2017 11:36 PM
tylerginevan
Apr 27, 2015 12:29 PM
shaejb15
Apr 26, 2015 07:44 PM
dooner24
Apr 14, 2015 07:51 PM
tattedlariat
Apr 12, 2015 07:55 PM
