Amp and Speaker Questions
Old Jun 27, 2008
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
Below is the listed specs of my amplifier but I was hoping I could get some help understanding certain things.
1) What does "Rated Power at X Volts" mean? Is this the amount of power I will get based on the voltage supplied by my car battery? Is it right to assume my amp will be receiving something between 12.0 - 14.4 volts?
2) What determines which impedance (2 or 4 ohms) my amp will encounter when powering speakers? Is it simply the speaker? Speaker descriptions usually say " XX watts at X ohms". So if a speaker says it has 2 ohm impedance, is that the impedance my amplifier will see?
Thanks a lot for the help.
Rated Power at 12.0 Volts:
* Five Channel (4 ohms): 40 watts x 4 + 130 watts x 1 (20 Hz-20 kHz, 0.05% THD) + (20 Hz-200 Hz, 0.5% THD)
* Five Channel (2 ohms): 60 watts x 4 + 200 watts x 1 (1 kHz, 0.5% THD) + (100 Hz, 0.8% THD)
Rated Power at 14.4 Volts:
* Five Channel (4 ohms): 60 watts x 4 + 200 watts x 1 (20 Hz-20 kHz, 0.05% THD) + (20-200 Hz, 0.5% THD)
* Five Channel (2 ohms): 80 watts x 4 + 300 watts x 1 (1kHz, 0.5%THD) + (100 Hz, 0.8% THD)
* Three Channel (4 ohms bridged): 160 watts x 2 + 200 watts x 1 (1 kHz, 0.5% THD) + (100 Hz, 0.5% THD)
Old Jun 27, 2008
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
Re: Amp and Speaker Questions
Watts = volts * amps
you are correct in saying the amp will see between 12-14.4 volts. In most situations itll be around 12.6.
The impedence on the speaker is how much resistance they give. The lower the resistance the amp sees, the more power can flow to the speakers. You can wire a two 4 Ohm speakers down to 2 Ohms by wiring them in parallel, aka on the same wire from the same amp terminal. You can also wire two 2 Ohm speakers down to 1 Ohm in parrallel.
redcloud
25
Aug 12, 2015 01:23 PM
jpandjf
Aug 3, 2015 05:02 PM
Nalmonte
Jul 22, 2015 09:08 AM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
