2003: is there an amp remote turn on wire from the factory deck
Old May 9, 2008
doctorhifi's Avatar
doctorhifi is an unknown quantity at this point
In my 2003 Civic LX sedan:
I want to use the factory deck to power an outboard amp (I'm replacing all the speakers).
I plan on using a step-down adapter (speaker level to RCA line level adapter) which I'll attach at the factory rear speaker wiring near the amp I'll mount in the trunk.
Trouble is, I need a remote trigger out of the factory deck to tell the amp when to turn on/off.
From the basic research I've done it doesnt appear that the factory deck has an amp trigger wire. Can someone confirm this or offer a solution?
I don't want to replace the factory deck at this time (I'm cash poor). I have Alpine/ADS gear that I pulled out of my 93 Accord so right now I have the amp and speakers and no money out of pocket.
2003 Honda Civic Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Blue/White
Car Radio Switched 12v+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): Red/Green
Right Front Speaker Negative Wire (-): Brown/Black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Blue/Yellow
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): Red/Yellow
Right Rear Speaker Negative Wire (-): Brown/White
Old May 9, 2008
Wpattie's Avatar
Wpattie is an unknown quantity at this point
Re: 2003: is there an amp remote turn on wire from the factory deck
theres two, well three things that can be done here. One is to use the Car Radio Switched 12v+ Wire: Yellow/Red. Two is figure out what wire is the Acessory On in your Ignition wires. Three is to run a wire from your battery with a fuse and toggle switch in the line right to your "remote on" on the amp its self.
Old May 9, 2008
Wpattie's Avatar
Old May 9, 2008
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Yeah accessory @ the deck or accessory @ the ignition harness (white/red).
PinkCupcakes
Electronics
Jul 18, 2019 12:50 PM
jackoncruzpr
May 24, 2015 12:24 AM
davidarenberg
May 16, 2015 08:45 AM
MamaBear2015
May 3, 2015 02:17 PM
LuvMyCivic
Dec 12, 2001 10:02 PM
