Amp Setup
Old Apr 30, 2008
Elix1r's Avatar
Elix1r is an unknown quantity at this point
Amp Setup
So I'm planning on overhauling my sound system in my 01 civic coupe this summer, and I was wondering how much my stock battery and alternator can handle. The plan is an alpine pdx-4.100 (4 channel 100w) for my interior speakers and an alpine mrp-m1000 (mono 1000w) for my sub. This should still be ok on the stock alternator and battery, right?
Thanks,
Elix1r
Old Apr 30, 2008
ciVictoria's Avatar
Re: Amp Setup
I'm pushing out a little more than that and I needed to upgrade my battery. It just was not holding up. I got a Stinger SPV35.
Old Apr 30, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
Re: Amp Setup
^^ i dunno. im pushin a jl 1000/1 and w7 turned down of course lol. and the stockers are doing fine.. i had to turn the amp down a lot though ahah.
Old Apr 30, 2008
hvc's Avatar
hvc
hvc is an unknown quantity at this point
Re: Amp Setup
it'll be fine. you don't NEED to upgrade, you can. but it's not like your stock components won't be able to power it.
it's all up to you.
Old Apr 30, 2008
KTciv_03's Avatar
KTciv_03 can only hope to improve
Re: Amp Setup
in the long run it could be a wise decision. dont rush into it though, just whenever you feel it necessary its always a good idea to upgrade alternator when pushing over a 1000 watts.
Old Apr 30, 2008
sl33pyriceboi's Avatar
Re: Amp Setup
get a cap for u amp. you should be fine.
Old Apr 30, 2008
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
Re: Amp Setup
what they all said. your good.
Old Apr 30, 2008
chkolny's Avatar
chkolny will become famous soon enoughchkolny will become famous soon enough
Re: Amp Setup
i would HIGHLY recommend the upgrade, people say it wont be too bad, but yes, yes it will suck without an upgrade, if i really giv'r on my subs, (i have about 500-600 rms) everything will dim down, i cant imagine 1000 watts with a stock alternator, your going to toast it quickly, and anyways, your going to get a much better response if you go to an audio specific forum like
www.canadiancaraudio.com
guys here are cool, and very knowledgeable, they will help you out much better than here
Old Apr 30, 2008
Unevolved's Avatar
Rough, Tough, Real Stuff.
Unevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to behold
Re: Amp Setup
I've always wondered... What kind of numbers can our factory alternator put out?
Old May 1, 2008
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
Re: Amp Setup
Plain and simple....Add a Cap 1 Farad and another 1 Farad for the other amp Bigger Batter and if that wont work change the Alternator in the future....Also use some 4 Gauge wire. Get a Good Ground....thats all i can give u
Old May 1, 2008
electric130's Avatar
Re: Amp Setup
stock alt = 70A max output
70A * 12v = 840watts max output.
so 110w for low beam headlights. at least 100w more for all other lighting at night. probably at least 200w for other car operations (ignition, fuel pump, fans, etc) and you can see that the power remaining for additional audio add ons runs out quick.
Old May 1, 2008
chkolny's Avatar
Re: Amp Setup
EXACTLY, stock alternator was built just for the car as it rolled off the assembly line, it was NOT designed for high power stereo systems and such (underglow neon tubes, led washer nozzles, neon exhaust ring, etc. haha) and i see capacitors as band aids, they dont solve a dam thing, they merely attempt to cover the problem up. If you intend to run your amp to optimal performance you WILL need a new alt., new battery/additional battery would be best, and a big 3 ground upgrade, plus anything else i may have missed. You cant just buy a amazing amp chuck it in the car and expect optimal bass-age, you need to do other upgrades besides simply a cap.
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
