If I changed my OEM Headunit....
Old Jan 7, 2008
DsevenEm2's Avatar
This is Myspace
Would I still be prompted for the security code needed when the battery is reset? I recently sold a muffler, and was thinking.. why the hell not. I might just go to best buy and pick up one of their Sony receivers for 100 bucks like this one:
http://www.bestbuy.com/site/olspage....#productdetail
Ive been wanting to get my ipod hooked up to my car as well, I could install it myself.. all i would need is the dashkit and wiring harness..
Whatd you guys think? Any input and answeres greatly appreciated
Old Jan 7, 2008
buckshizzo's Avatar
buckshizzo is a jewel in the roughbuckshizzo is a jewel in the roughbuckshizzo is a jewel in the rough
Re: If I changed my OEM Headunit....
I say go for it. The stock head unit isn't great and you won't need the security code with the new head unit.
Old Jan 7, 2008
Rennen's Avatar
New Mod on the Block
the security code is an option in the stock head unit. you wont have security code. if you get the stuff from the store, best buy usually has free installation.
Old Jan 7, 2008
DsevenEm2's Avatar
This is Myspace
i found an even better deal
http://www.crutchfield.com/App/Produ...GT410U&tp=5684
all that for 149.99..
that includes the receiver, install kit, and wire harness plus free shipping. and itll match the colors in the dash.. it seems like a great idea to me. it even has a usb port on it.. i think ima go for it.
Old Jan 7, 2008
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
i got my alpine 9883 with the ipod link for $200. BBY wont install it unless you bring them the parts. (For the 7th Gen Civic)
Old Jan 7, 2008
might as well pick up a cheap alpine. the sony will be nothing but problems
Old Jan 7, 2008
Envy's Avatar
Diamond Member
if your going to expand your stereo, getting low power wont matter. Just be sure to get one with lots of pre-outs. At first all I wanted was a nice stereo, so I bought my $200 Alpine (a lot for my 16 year old self) with 18 RMS x4 and 50x4 peak. Stock Speakers: 12-15RMS, 45Maxx. I blew my fronts pretty quickly. So now I have amped alpines in the doors and I wanted more bass so I got subs. Im now $1000 into my stereo. lol. Focus on the end result.
Old Jan 7, 2008
phuviano's Avatar
Slowest 7thgen in the GTA
I say do it if you really want to hook up your ipod to your deck. Also, why get that deck, when you can get this one. http://www.crutchfield.com/App/Produ...IP&c=3&tp=5684
Its got a built in ipod attachment. With the deck you posted, you need to buy an ipod adapter.
If your only concern is to hook up your ipod, buy this deck. If you are concern with SQ, I'd suggest other brands. Alpine, Pioneer, and JVC isn't bad.
Old Jan 7, 2008
DsevenEm2's Avatar
This is Myspace
ive actually had my system and speakers running off of my oem unit for quite some time now.. about 2 years im guessing. its been great for me, im not looking for an amazing sound change or to expand my system. ive upgraded my speakers, and ive had my sub amp combo hooked up via a converter. i just figured i might as well get a deck, to support an ipod and to not have anymore code issues.. once and for all you know?
and with the second link i posted, that deck doesnt need an ipod adaptor. It only needs one if you plan to use the deck as a MOC. I can control the ipod..from the ipod, i dont need to use the deck for that. Itll do the same thing as the other one you posted, and for 20 bucks more, i think its probably worth it. it looks nicer, and its got the usb thing.. and i dunno..
whatd u think?
edit: can somebody please review the last link i posted and verify that you CAN use an ipod without the adapter, however cannot use the deck as a means of control. I think you can still connect it and use it and listen to it through the deck, but you cannoy control it, with the buttons on the deck. Am I wrong??
Old Jan 8, 2008
fallout's Avatar
fallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the rough
For the same price, why don't you get this one? This is a pretty old model, but it'll do much better than the Sony in the long run.
http://www.crutchfield.com/App/Produ...&tp=5684&avf=N
When it comes to cars, stay away from Sony. The alpine will give you much better SQ. This one has a connection for an ipod adapter in the back, but an ipod controller unit (which lets you control the ipod from your deck) will run you $100+. However, the front has an aux input. You can get this cable for like $10 and connect it from your ipod to the deck. You can't control it from the deck, but it beats spending $100 bucks.
Old Jan 8, 2008
if you run speakers directly from the new deck, be sure you do the power/ground wire upgrade mod it makes a noticable difference esp with the alpines. it will use the extra power. i only have tweeters hooked to my alpine, but when i did the mod, i had to turn down my treble by 1db cause they were so much louder.
Old Jan 8, 2008
DsevenEm2's Avatar
This is Myspace
where can i find that mod gearbox?
also another big reason i wanted the sony, was just a dumb pet-peave of mine. most the ones ive seen had a green display or something other than the orange-redish color on our dashes.. i duno i just think it looks tacky, but that one FALLOUT posted looks pretty neat.. i may just opt for that one
Old Jan 8, 2008
instead of using the factory civic harness for power wire (yellow/batt) and black (ground), run new thicker wires directly from the deck harness to the battery + and chassis ground. just for those two wire tho, thats how the deck gets its power. the ign ignition wire is just a trigger and you are fine using the stock harness for that. the batt and ground wires are just too tiny for a hi power deck. and the factory ground location isnt the greatest either.
Old Jan 8, 2008
DsevenEm2's Avatar
This is Myspace
ahh.. i see. so the yellow wire on the wiring harness is yellow. should i just wrap that one up or pull it out and get it out of there? same with the ground? then from the deck itself, i can just run thicker + and - wires str8 to the battery (and chassis for -)
im pretty sure i get it.
does anybody else think that alpine posted before is a good choice? i asked around a bit more and yea i guess the sony wouldnt be the best option.. thanks guys.
Old Jan 8, 2008
i have the 9847 and it has an amber and a green mode, and a couple other combo colors. really nice for 200 straight from the store. and cheaper decks are just as good. you dont need a bunch of preouts if you never plan to amp the speakers.
Old Jan 8, 2008
DsevenEm2's Avatar
This is Myspace
http://www.crutchfield.com/S-5TVVESC...&tp=5684&avf=N
then i think im just going to stick with this one. Ill keep my subs/amp and just connect them from the one set of the 2 pre-amp outputs. I actually already have that aux cable for my ipod. I got one with my iHome. Its actually the same cable. So I think i'll be ok. Thanks guys. Alpine ftw!!
Old Jan 8, 2008
that one you posted looks good. and to be honest, cheap alpines sound just as good as the expensive ones. all i have is treble and bass adjusters and thats really all you need.
Old Jan 8, 2008
HonCiv02's Avatar
HonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond repute
alpines are solid headunits. i have never had any problems with them and neither have my friends; i think you will be really happy with it.
Old Jan 8, 2008
DsevenEm2's Avatar
This is Myspace
well thats good to know then. thanks again..
if anyone has ANY OTHER recommendations besides alpines.. or even different alpine models you think might be better for me. please post up!!
Old Jan 8, 2008
hXc drummer23's Avatar
hXc drummer23 will become famous soon enough
Try sonicelectronix.com
They give free installation kits and a wire harness with every headunit. I recommend Pioneer. The headunit I got was $400 but they have some that are a lot cheaper.
Old Jan 8, 2008
DsevenEm2's Avatar
This is Myspace
yea these too offer the free install kits and wire harness.. ill hit up that site tho, thanks bro
Old Jan 8, 2008
DsevenEm2's Avatar
This is Myspace
ok after looking thru that one site, ive found this:
http://www.sonicelectronix.com/item_...+CDE-9873.html
now can somebody tell me whats the difference between that 9873 model and the 9874 model that i posted back from Crutchfield.com? This one:
http://www.crutchfield.com/App/Produ...ures_and_specs
The 9873 model is $30.00 cheaper!! Why wouldnt I just go with that one, I cant see any major differences, can anyone figure this out??
EDIT: The one from SonicElectronix doesnt include free shipping, so it totals to 137.31 lol ok so its $10.00 cheaper. Still, should I go with that one and save the 10 bucks??
Old Jan 8, 2008
fallout's Avatar
Well for one thing, the 9873 does not have a front aux input. Reading more on the fine print, it doesn't have an aux input at all! So therefore, you would not be able to use your ipod. You would have to spend $30 to buy the ipod adapter , which would cost you an extra $20+ including shipping for both.
Old Jan 8, 2008
DsevenEm2's Avatar
This is Myspace
*THUD*
I couldve caught that.. yeap my best option would be the 9874 from Crutchfield. Im pretty much set on it.. thanks guys.
Old Jan 11, 2008
civicarina's Avatar
civicarina will become famous soon enoughcivicarina will become famous soon enough
I would always go for this one dude !!!
http://www.bestbuy.com/site/olspage....1&type=product
I might get this one next month. My brother replaced his 04 Camry's OEM system with this Kenwood. Let me tell u this. Me and my bro went to get the Head unit and Aftermarket speakers. But when we chose this deck, the sales guy told us not to buy after market speakers right now and just get the HEadunit. After the installation, we were surprised as hell!!!
The salesman saved us like 200 bucks in speakers coz we thought the OEM ones had blown. But only this Kenwood like gave a new life to those speakers :-)
Old Jan 11, 2008
lordhelmet's Avatar
I rolled with just an older model of that kenwood deck for a couple of weeks before I got my speakers put in and lets just say those speakers were shot. Im betting camry speakers are slightly better than civic speakers are.
Old Jan 11, 2008
thats the key. older kenwood. their newer stuff is junk. my first deck was kenwood actually, when they still had those cool triangle power buttons and clean looking black decks.
Old Jan 11, 2008
Kevbotron's Avatar
I like my commute
^werent you all about Evenescence?
Old Jan 11, 2008
lol? what does that have to do with anything l
Old Jan 11, 2008
Kevbotron's Avatar
I like my commute
I dunno hah.. being random I guess I remember a while back u had an evenescence sig which was triggered by talk of HU's hah
