Just a question?
Old Sep 6, 2007
jakes01civic's Avatar
jakes01civic will become famous soon enough
Just a question?
Ok heres the situation. I have a 2001 civic ex. The positive battery cable has 4 wires on it, 2 run to the fuse box under the hood, 1 runs to the starter, the 1 runs somewhere else. My question is Where would the 4th wire run too? Would it run to the fuse box under the dash? Where else would it run because i can't see where it runs.
Thanks for any advice.
Old Sep 6, 2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Re: Just a question?
Alternator.
Old Sep 6, 2007
okay i pulled the column and i pulled out the ignition switch and i used a screwdriver to try and start it. it started right up. Would it be the lock cylinder then?
Old Sep 6, 2007
Huh? 01 Civic should have an immobilizer.
Old Sep 6, 2007
It does have an immobilizer. But what does that have to do with the lock cylinder???? I'm confused......... It starts with a screw driver when the key is in the ignition and i turn the ignition switch.
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
junkyardguy
Sep 2, 2015 06:07 PM
