Largest sub box size?
Old Jun 6, 2007
hdave's Avatar
hdave is an unknown quantity at this point
Hello guys,
I have a 2005 Civic Sedan and want to know whats the largest sub box i can fit in there? Max width, height, and dept dimensions that can fit in there without removing anything.
Thanks,
Harsh
Old Jun 6, 2007
D16Z6_owner's Avatar
D16Z6_owner is an unknown quantity at this point
Re: Largest sub box size?
tape measure......................................
Old Jun 6, 2007
DsevenEm2's Avatar
This is Myspace
ruler. or you can google in to find out specs on your car. i had a huge box in mine for 2 15's at one point. its a tight fit but u can manage it with a little patience. its just heavy as hell and probably not worth it. why do u want such a big box anyways?
Old Jun 6, 2007
SSMCivic2k5's Avatar
SSMCivic2k5 has a spectacular aura aboutSSMCivic2k5 has a spectacular aura aboutSSMCivic2k5 has a spectacular aura about
i have a kicker 10'' l7 box. fits PERFECT in the most far part of the trunk. im actually sellin it if ur interested
Old Jun 6, 2007
DsevenEm2's Avatar
This is Myspace
i have a box for 2 12's thats pretty big. brand new and custom made. and never used. im actually sellin too if ur interested lol.
Old Jun 6, 2007
hdave's Avatar
Im going to make a box for my 2 15s
I measures and know the max dimensions, but I want to know the max dimensions that can fit in and out of the trunk
Old Jun 6, 2007
chawski's Avatar
chawski will become famous soon enoughchawski will become famous soon enough
yet again...
tape measure
Old Jun 6, 2007
0H3ebpEM2's Avatar
0H3ebpEM2 will become famous soon enough0H3ebpEM2 will become famous soon enough
use a tape measure and measure the dimensions of your trunk. then use winISD to help make your enclosures
Old Jun 6, 2007
Syke Fu's Avatar
Syke Fu will become famous soon enough
Man that's gonna be one big box. I hope you never have to change a flat tire.
Old Jun 6, 2007
DsevenEm2's Avatar
This is Myspace
look at the max demensions..now take off about...6 inches off of each side. and that will let u know what size box u can take in an out with no problem. which seems pointless to me anyway. what kind of 15s are u gona use. the bigger the box doesnt always mean the better the sound. what do u hope to accomplish. u can fit 2 15's with a small size box. its not like 15s wont fit. but u really dont need a box thats gona be the max size of ur trunk.
Old Jun 6, 2007
hdave's Avatar
The 15s will be in a sealed box, even a box thats 34" wide 15" high and 15" deep would only provide 1.7 cubes each, for optimal sound these subs need 2.25 - 2.5 cubes each. I am not trying to just simply cram the biggest box possible.
subtracting 6 from the max possible dimensions is just plain stupid because I know the max width is about 34" and max height is 15" I pretty much want to know what the max depth I can fit in there.
And theres no way to actually figure out what size box will fit in and out of the opening without actually trying it so stop saying tape measure. I was just hoping someone here had actually built a large box and had some input instead of some smartasses increasing their post count with useless posts that don't help.
Old Jun 6, 2007
bakertime's Avatar
bakertime is a jewel in the roughbakertime is a jewel in the roughbakertime is a jewel in the rough
The problem is that depending on the height, different depths will fit in the opening (picture how it's going to hit the floor when you put it in the opening). If you set on a 15 height, then make a template out of a peice of cardboard. Make it 15 inches high, and LONGER then you think you'll have the depth. slide it into the trunk perpedicular to the floor on it's edge. When it gets stuck, that's your max depth. Just get out you're trusty tape measure...
If you're not happy with that size, then try a smaller height and do the same.
Old Jun 6, 2007
hdave's Avatar
Great idea, Im going to go out and work out something 15" high, 34" wide and will mess around with the depth.
Old Jun 6, 2007
HondaKorn's Avatar
Life is better with 5lug
ive got 1 15"
Old Jun 6, 2007
PopcornPlaya's Avatar
Electric Boogaloo...
How big is your trunk? That's how big it can be, as you can use a baffle board and the entire trunk would be your enclosure. Personally, I'd check the TS parameters and figure my box then see if it would fit in there.
Old Jun 6, 2007
hdave's Avatar
This is a sealed box for 2 15" CVRs
min is 1.8 each, max is 5.2 each according to kicker.
im planning on giving them about 2.25 cubes each.
Old Jun 8, 2007
DsevenEm2's Avatar
This is Myspace
i hate when people make a thread and then get mad at all the responses.. look at what u posted dude. u asked what is the max height. if u wanted to know if anybody had the largest box possible, then u shouldve asked that. instead u ask whats the biggest a box can be? alot of us probably dont know becuz we've never tried. be mroe specific about what u really want, for that kinda question we might as well tell u to do it urself and let us know.
Old Jun 8, 2007
D-Vus CIV's Avatar
my civic gets me pu**y.does yours???
D-Vus CIV can only hope to improve
i have a 15 l7 solobaric in a 4.5 cu ft box.its a really tight fit. the box is
32x17 3/4x19.like i said it is a tight fit.i spent like an hour or two getting it to fit but the sound is really good.it hits like noneother.but it weighs like 80 some odd pounds.
Old Jun 12, 2007
hdave's Avatar
i made this one:
34" wide
15.5" tall
and 19" deep
I can probably still throw another inch or so in depth if i wanted to just incase anyone else wanna cram big subs in there lol
Old Jun 12, 2007
mneuls's Avatar
mneuls will become famous soon enoughmneuls will become famous soon enough
i think the biggest you could get would be to take out your back seats, fiberglass the trunk and wall it off.
Old Jun 13, 2007
allyoucaneat's Avatar
allyoucaneat is an unknown quantity at this point
maybe you could fit a bigger box in the trunk if you put it thru the back seat gap...i cant measure it right now but if you want me to ill get back to you tomorrow...but it might be a big pain in the *** if you need to change a tire since you cant just simply pull the box out the back
Old Jun 13, 2007
electric130's Avatar
ummm.....yeah there is. just some simple calculations will tell you what will fit. and to be honest, you original post does come across as someone who's just looking for a easy solution and not willing to do any work for themselves. so based on the original post, i'm not surprized at the answers.
Old Jun 13, 2007
hdave's Avatar
well i ended up trying a few different sized by making a cardboard box.
Old Jun 28, 2007
mneuls's Avatar
you know that there are calculations of size to optomize the performance of the subwoofer based on resistance and power and throw and alot of other things. doing these calcs and building the airspace required will save you alot of trouble, and make your subs sound better, if your box is too big, the subs have less air resistance, and it makes them throw farther, but sound worse and wear out alot faster. use the box size recommended for your sub. you might even be able to put stuff in your trunk if you do it right, or you could have enough room to build a false bottom in it to put your weed in.
Old Jun 28, 2007
fallout's Avatar
fallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the rough
34" wide isn't gonna cut it. If you use 3/4 MDF wood, you have to take displacement into consideration, that comes out to about an extra 3 inches. Plus the diameter of the sub isn't actually 15", it's wider than that, depending on brand. You need a least 36" width, and that isn't gonna fit. I spent 3 weeks figuring out how to do this, but there's no way to get the box in there. I built about 6 cardboard boxes, and the smallest one would not even fit.
Old Jun 29, 2007
mneuls's Avatar
no dude, i've seen two 15's in a 2005 si coupe before., what would be sweet is if you made two separate boxes on the sides and fiberglassed them, i've got mdf ones for 10's and they look good. or you could just get rid of one of your subs, buy a couple tens, and put all three in there, and actually get some decent sound quality.
note: the box I saw had the subs facing slightly away from eachother, like a slight triangle, and the front was sloped down about 45deg.
krazykoncepts
Jul 14, 2015 01:55 PM
