System Trouble Help
Old Mar 26, 2002
Phatster's Avatar
Phatster is an unknown quantity at this point
System Trouble Help
I have a question if someone can answer it great if not oh well.
My amp turns on but there is no sound coming out of my speakers and I have checked the RCA's and bought new ones and everything and still the same stuff happens, Nothing. I have 4 ga. ran into a distibution block and then 8 ga. runnin to two amps and they both do the same thing. Any suggestions would greatly be appreciated.
Old Mar 26, 2002
Subrage's Avatar
Subrage is an unknown quantity at this point
check to make sure your amps are not in protection mode
Old Mar 26, 2002
Fr0stBite's Avatar
Fr0stBite is an unknown quantity at this point
Like Subrage01 says make sure u'r not in protection mode. And check the gains etc. I had a similiar experience thinking something was wrong with the line from the HU but turned out my gain was set wrong and voila no sound. =(
Fr0stByte
Old Mar 26, 2002
Phatster's Avatar
I have checked it and my amps are not in protection mode. I have been doing car stereo for a while and this is a first for me I hve never seen anything like this. It is making me mad as well. Any other suggestions would help
Old Mar 26, 2002
mohawkboom's Avatar
I've seen this before.. if you checked your RCA's and such and still no sound at all.. Check the voltage at yuor RCA's if it's ZERO..your HU's output stage is deffective..
\Cheers
Mohawk
Old Mar 27, 2002
Phatster's Avatar
So if my level is zero that means my head unit is messed up? Now should I send the head unit back in and tell them to fix it or what? Thanks for the help man.
Old Mar 27, 2002
mohawkboom's Avatar
if the HU's defective it's under warranty..so yup send it back
Old Mar 28, 2002
Phatster's Avatar
This might sound dum of me but do I just put the voltage meter on the RCA output from the back of the HU? Thanks
Old Mar 28, 2002
mohawkboom's Avatar
Yup.. or you can do it from the RCA's in your trunk.. just put one lead on the center ppin.. one lead on the outsode ring and turn the volume up on your HU..play a CD and see if you get any Voltage reading
Old Mar 28, 2002
Phatster's Avatar
Hey man I appreciate all your help. Thanks a bunch I will let you know what happens. thanks a bunch
mjdiaz89
Jun 21, 2016 09:26 PM
carid
Nov 7, 2015 01:46 AM
liagreenhalgh92
Jul 21, 2015 01:31 PM
