bass knob
Old Apr 3, 2007
mike21190's Avatar
mike21190 is an unknown quantity at this point
bass ****
im looking for a bass **** so i can control my subwoofer and amp without having to go into my trunk. i have a 12" jbl sub and a pioneer GM-5200T amp. anyone know of a **** that will work with that amp?
Old Apr 3, 2007
MotorWeb EM2's Avatar
MotorWeb EM2 is an unknown quantity at this point
Re: bass ****
just to help u out. its called a gain control ****, just so more people know what your talking about. sorry though, i dont know what would work with it. try contacting pioneer and see if they make one for their amp.
Old Apr 3, 2007
Re: bass ****
depends on the amp you have, theyre not universal
Old Apr 3, 2007
85gp4's Avatar
85gp4 is an unknown quantity at this point
Re: bass ****
I don't think your amp is setup for a bass gain conrol ****. Every amp that I have ever seen with a bass gain control option, has what looks like a telephone connection where you plug in the cable. Crutchfield has some pretty good pictures of your amp, and I do not see any connection for the bass gain control. Pictures of your amp can be seen here:
http://www.crutchfield.com/S-RmNAc3y...120#morephotos
This amp has an option for a bass gain control and it has the connection. See picture
http://www.crutchfield.com/S-RmNAc3y...&display=L#Tab
Hope this helps...
Old Apr 3, 2007
PaCiFiKbAllA's Avatar
PaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond repute
Re: bass ****
^^ same as above. although the higher end pioneer premiers might be equipped with one.
Old Apr 3, 2007
JMUCivic03's Avatar
JMUCivic03 is an unknown quantity at this point
Re: bass ****
Im going to go ahead and say you are probably better off without a gain **** in the cabin, because that will kep you from fiddling with it every 5 seconds or every other song. Gain is meant to be set at the loudest point you listen to music and can begin to hear distortion. If you adjust your gain to high, you are getting a alot more distortion and will drastically shorten the life of your speaker.
Old Apr 3, 2007
85gp4's Avatar
Re: bass ****
And/or blow your amp!
Old Apr 3, 2007
Re: bass ****
not all of them look like phone plugs. the one for my mtx thunder elite amp uses what looks like a headphone jack. so maybe yours is a different kinda too....i dunno though.
Old Apr 3, 2007
Alpha 5's Avatar
Re: bass ****
Why don't you just use the Bass controll on the HU or even the Fade. Fade it to the front Vocals > Bass fade it to the rear Bass > Vocals. Not the best solution but deff the cheapest.
Old Apr 3, 2007
mike21190's Avatar
Re: bass ****
alright thanks for the help
Old Apr 3, 2007
Alpha 5's Avatar
Re: bass ****
^^^^^^^ If we helped, rep those that help. They will return the rep.
There is too much help going around with out the rep in return.
Old Apr 3, 2007
hvc's Avatar
hvc
hvc is an unknown quantity at this point
Re: bass ****
Yeah depending on your deck, it may have Sub control. If it does, the GCN is sort of pointless. Just turn your sub level up and down on your HU. way cheaper
Old Apr 3, 2007
JMUCivic03's Avatar
Re: bass ****
Too true, it seems as though not many people around here rep even when someone does help. Now if someone could just explain to me what the points sytem and stuff does, ill be good to go.
Old Apr 4, 2007
Alpha 5's Avatar
Re: bass ****
^^^Just do a search, there is a thread about the points.
Also, thanks for the rep. I would rep back if you had left your sig in the rep. So whoever reped me please PM me so that I know who you are and I can return the favor.
Jrosa
Sep 14, 2015 08:24 PM
Civic720
Sep 10, 2015 10:06 AM
junkyardguy
Sep 2, 2015 06:07 PM
naokigoffi
Aug 30, 2015 06:19 PM
Deeup511
Aug 30, 2015 04:48 AM
