Aftermarket speakers
Old Mar 15, 2007
gFused's Avatar
gFused is an unknown quantity at this point
Question Aftermarket speakers
I'm trying to search for aftermarket speakers for my 04 Civic LX sedan. I went to Best Buy and Circuit City, and checked online at Crutchfield's, and the systems show that my car will fit 5 1/4 or 6 1/2 speakers on the door. Is this correct? How is this possible? I don't want to remove the speaker to find out what I need. I wish there was concrete answer so that I can start deciding on which ones I want. Anyone know what size I need?
Old Mar 15, 2007
PowerWheels86's Avatar
PowerWheels86 is an unknown quantity at this point
is it a four door? sorry i'm not very keen to newer model Civics... it might be that the front doors are 6 1/2 and the rears are 5 1/4 by the way i hope you were going with pioneer speakers for aftermarket speakers......
Old Mar 15, 2007
gFused's Avatar
Its a sedan so its four doors. My front speakers are on the door and my rear speakers are on the deck.
Old Mar 15, 2007
i'm gonna say 6x9 on the deck in the back and 6 1/2 should fit on the front door... just because your stock speakers might be 5 1/4 doesn't mean 6 1/2 won't fit... i would say just take the panel off to make sure... you have to take it off anyway to replace them... might as well do it right before you make the trip to the store to buy them...
Old Mar 15, 2007
HyeHonda05's Avatar
Official Wish He Knew It All
yeah....6.5'' in the front and 6x9 in the rear.....
Old Mar 15, 2007
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
uhhh, sedan is 6.5 all the way around
and coupes are 6.5 in the fronts and 6x9's in the back
Old Mar 16, 2007
well check the back brackets gfused... they might have a space that would fit 6x9's but they placed 6 1/2 in there it never hurts to look... all you have to do is open the trunk and take a gander under the rear deck...
Old Mar 16, 2007
rice4lyfe's Avatar
uhh what? he said sedan....
6 1/2 all the way around
Old Mar 19, 2007
sugisan's Avatar
sugisan is an unknown quantity at this point
sedans are all 6.5s. i don't think you'll be able to put in aftermarket speakers without making or buying spacers for the doors. i believe spacers on crutchfield will fit both 5 1/4 and 6.5 speakers. just make sure that you have enough clearance for the magnets.
Old Mar 19, 2007
JMUCivic03's Avatar
JMUCivic03 is an unknown quantity at this point
Yeah the sedans are 6.5 all around. If you have the after markets professionally installed, you shouldnt run into any problems. However, if you are doing the install yourself, you need to know that honda uses a very weird mounting system for their oem speakers that uses pressure clips on the front doors. For this reason, there are no pre drill holes that will accept screws from your new speakers, therefore and adapter will be needed. Also keep in mind the depth of the speaker. Speakers that are too deep are going to hit on the window, and you wont be able to roll it down all the way. I have the depth from the door panel, where the speaker would be mounted flat, to the window when it is rolled down at about 2-2/18". <----Just an approximate measurement. I just saved myself the trouble of having a problem and bought shallow mount speakers for the front doors (jbl p652s). Also keep in mind that while normal 6.5 speakers are obviously round, but the hole in the front door is a very weird shape, almost like a circle with a flat edge on one side (if that makes any sense). If you are buying 2/3/4/5 way speakers, remember to take into account how far the tweeter sticks out above the speaker, because it might hit the plastic grill on the door panel. And FYI, crutchfield's fit guide for speakers is usually right and is a decent reference, but it was wrong in my case and told me that my jbl speakers would not fit when they actually did. Hope this all helps.
Mad Dog Tannen
Oct 19, 2016 08:12 PM
UltraHDGames
Jun 8, 2016 05:16 PM
bhollie
Sep 22, 2015 11:08 PM
Gsxtacy
Sep 12, 2015 01:09 AM
redcloud
Sep 7, 2015 01:45 PM
