single subwoofer rca preout
if you have ONE output, and ONE input on ONE amp then there is no problem, plug it in and problem solved. if you are running more then ONE amp, buy a short rca cable and run it from the OUTPUT on the first amp (if it has one) to the INPUT on the other amp.
^^^^ to clear this up so i dont sound retarded. yes i only have one amp and yes theirs only one sub output. that one sub output was a single meaning only one rca jack not two. i just bought a Y and used it to connect both RCA's to that one jack
if you run your amp in bridged mono, you should only need one.
redcloud
Sep 7, 2015 01:45 PM
wingsfan19
15
Sep 2, 2015 02:15 AM
