12W7 and ported box system
hey guys i was wondering if the ho112r-w7 ported box would fit in my trunk. i have a 2003 honda civic hx. heres a website to the sub with the dimensions and specs. JL Audio: Products
i really hope this will fit. nice sub from awesome company.
It should fit but best thing to do is take a tape measure, and measure the opening of the trunk and then the height of the actual trunk and compare to the demensions. 17in tall, 34in wide, and 20.5in deep is what they say for the box if you didn't see that.
lol i dont want to do that. yeah i saw the dimensions of the box, but i wasnt sure if it would fit in our trunks or not. i figured you guys might know. do you think 17" is too high and it wont fit?
the problem will come from it hitting the speakers if you slide it all the way back but if you leave it close to the trunk lid then your good i think
alright..... thanks big guy. i really hope this box will fit. this is one heck of a sub. i want the 12's back i've had my 15 for awhile now but i miss the 12's so hopefully it will fit
Okay here is how you can be sure it will fit if you didn't pick up on it before,
1. Get measuring tape.
2. Open trunk.
3. Measure dimensions (including height) in the back of your trunk.
4. Compare to dimensions of recommended box.
Troubleshooting: If it does not fix slightly modify recommended box.
Not to be an *** but I kind of think this is a silly question.
2. Open trunk.
The World Is Yours!
i had HIFIBuys install to the sub's enclosure specs, so it works flawlessly in my trunk.your dimensions sounds correct. i mean if i can get a 13W7 to fit and no problems, yours will be ok. mount some tabs around the box to prevent it from moving around... mine DID..
