attn mohowk
Old Mar 18, 2002
lilbluecivic's Avatar
lilbluecivic is an unknown quantity at this point
attn mohowk
im probably going to start building my box for my 4 12" audiobahn awt12's.where can i find the dimensions for the box ,it's replacing my back seat.thanks for any help in advance.
Old Mar 18, 2002
CrankinCivic's Avatar
CrankinCivic is an unknown quantity at this point
first check with audio bahn .. or look at your theile small paramaters and it will tell you .. how large each enclosure should be ..
Old Mar 18, 2002
mohawkboom's Avatar
sealed 1.33 cubes each or there abouts for those subs... To fit 4 subs replacing your back seat is gonna be alot more work that you think bro[IMG]i/expressions/face-icon-small-smile.gif[/IMG].. The best advice I can give you is pre-measure everything.. measure it again. Build 2 seperate enclosure that can bot fit into your trunk and Built a faceplate with the 4 subwoofer openings and use that as the back seat...
Cheers
Mohawk
Old Mar 18, 2002
i was told to use 2- 3in. wide ,9in long ports per sub.do you think i should use a sealed box.
dezod
Mid Atlantic
Aug 19, 2007 07:57 PM
RHCP0801
Oct 11, 2006 10:38 PM
DMikeX
South Cali
Jun 27, 2005 01:51 PM
RIC3BOY
Aug 18, 2003 10:16 AM
dezod
Mid Atlantic
Jul 15, 2002 11:41 PM
