Window hitting speaker
Old Nov 10, 2006
Nas0827's Avatar
Nas0827 is an unknown quantity at this point
I put my mbquart components in the passanger side today and i noticed that when i put the window down at the very bottom i can hear the window hit the speaker... What do you guys think i should do? is it fine to leave or can i do something to stop it?
Old Nov 10, 2006
LiKEaFeRiO's Avatar
Did you install it using a spacer?
If not, then I suggest you buy a 1/2" or 1" spacer.
They are less than $20 a pair at your local shop or if you have the tool, make one.
Old Nov 10, 2006
Nas0827's Avatar
Tried using a 1 inch spacer before and couldnt get door panel back on. ill look around for a 1/2 spacer. Also i took off that clear stuff to keep water out last week cuz i dynamated it today and i saw that all the wires had goten wet i guess cuz it rained. since i dynamated all the holes should that cover it?
Old Nov 10, 2006
civic01vtec's Avatar
I made my own spacers.
Old Nov 10, 2006
LiKEaFeRiO's Avatar
Look in the back of the plastic door panels.
Trim off some of the plastic where the speaker grill is.
Look and you'll know what I'm talking about.
That should do the trick.
Old Nov 10, 2006
jay47's Avatar
jay47 is an unknown quantity at this point
Ok, I have some infinity references (componenents) up front and all I did was take some 3/4 mdf and cut out my own spacer. It was really easy and did the job. Doesn't look to great, but I you could paint it or do whatever you needed though
Old Nov 11, 2006
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
I made a 1/2" spacer and that's what worked for me but I had the same issue with window obstruction as you did. It's real close so you don't need to add much space. 1" is definitely overkill.
Old Nov 11, 2006
Nas0827's Avatar
put a spacer in and moved it down a little and window still taps it a little. guess im just gonna leave it
Old Nov 11, 2006
juanotejano's Avatar
juanotejano is an unknown quantity at this point
If you haven't tried cutting some of the extra plastic out of the speaker cover thing then I would suggest trying that and using the biggest spacer that will fit, that worked for me, but if it doesn't really matter to you then just make sure your passengers go easy on the windows.
Old Nov 11, 2006
Eightball's Avatar
Eightball will become famous soon enoughEightball will become famous soon enough
I just cut the center out of the old door speakers, screwed the new ones into the old speaker frame and soldered them to the old connector. They plug in and clip into the door like the stock ones
Old Jun 4, 2017
Devan Lucas's Avatar
Devan Lucas is an unknown quantity at this point
Re: Window hitting speaker
use longer screw's and lots of washers. cost me 3 bucks at walmart
dtdoyle
25
Aug 30, 2015 06:57 PM
mrwhos
Aug 11, 2015 02:03 AM
jpandjf
Aug 3, 2015 05:02 PM
Nalmonte
Jul 22, 2015 09:08 AM
