sub box mounting
Old Nov 9, 2006
topher civic's Avatar
topher civic is an unknown quantity at this point
sub box mounting
hey hows every one doig? I have a 2001 civic and i cant get my sub box from moving around and i was wondering if any one has any ideas on how i could mount it with out having to drill or screw it into my car. ohh and its in my trunk up against my back seats. thanks
Old Nov 9, 2006
SOAD's Avatar
SOAD is on a distinguished road
i know some people who used those velcro straps, seemed to work good for them
Old Nov 9, 2006
hey i have those between my box and carpet stuff but it all moves around
Old Nov 9, 2006
SOAD's Avatar
hmmmm nothing else that i know of besides drilling and all, maybe someone else knows
Old Nov 9, 2006
junior h.m's Avatar
junior h.m is an unknown quantity at this point
just use small mini size L steel straps
Old Nov 9, 2006
CenZ's Avatar
PWIT
i know alot of people use the mini L shaped brackets to hold it in place, they drill it right to the car.
Old Nov 9, 2006
Nas0827's Avatar
Nas0827 is an unknown quantity at this point
Yea i use the L brackets and works great
Old Nov 9, 2006
thefever's Avatar
I need a drop
thefever is a jewel in the roughthefever is a jewel in the roughthefever is a jewel in the rough
drill it to the cheap *** cardboard.
Old Nov 11, 2006
liquidride59's Avatar
liquidride59 is an unknown quantity at this point
Thats what i did but the screws pulled out.... To many quick moves maybe....
Old Nov 11, 2006
WhiteRabbit's Avatar
if you do not want to drill into the car, you can use an alternate method (you wont like it) to solidly mount your subwoofer box.
you can cut a piece of plywood 1/4 to 1/2 inch thick (1/2 inch is better) the approximate size of the trunk. the two lazy methods are:
#1 copy your trunk floor carpet as a template. its not perfect, but it shouldnt wiggle too much.
#2 cut the wood as wide as the wheel wells and test fit the sheet, making cuts until the front curvature matches the stock panneling around the trunk latch. This is very solid, but does not leave your trunk flat.
you can add the wings to either side of #2, but it might be more work than you want to perform.
once you have a solid base to work from, simply screw the sub box into the floor from the inside. you will have to remove the subwoofer to do this. no ugly mounting brackets visible, this way.
floor goes no where and the box is attached to the floor. not the simple solution, but it saves you from poking two screwholes into your trunk floor sheet metal.
your other alternative is to find a couple places that have stock bolts/threads (the support struts to stiffen the rear deck, for example) and install backstrapping using those preexisting mounts. you can then run the backstrapping to your box and screw it in. saves you from drilling holes if you dont mind exposed strapping.
Old Nov 11, 2006
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
use the industrial strength velcro and it wont move an inch. make sure its clean where you stick the stuff down tho
alaga
25
Aug 13, 2015 04:42 PM
WaryDriver
Aug 8, 2015 05:08 PM
