Speaker size
Old Oct 15, 2006
ultimatetuner10's Avatar
Technical Assistant
ultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond repute
Speaker size
I went to circuit city, to get some speakers. The back of the box of the 6x9s says it fits coupe/sedan civic 95-05...same thing for the 6.5 inch. I get to installing them, and what do you know, the 6x9s dont go ANYWHERE, and Im ****ed. I return the 6x9 spekaers, but didnt get anything else for now. I have the 6.5 inchers laying next to me, so my question is this
What size speakers go into the 2001 honda civic SEDAN...both for the front doors and the back panel. THe guy looked at my back speakers and said they look like 6.5s, so thats why i kept them, but he siad he cant tell the size of the fronts thru the doors, and said that their comp is often times wrong. He said the front doors are 6.5 as well as the back. What is the actual size of speakers that goes in my car
Old Oct 15, 2006
thefever's Avatar
I need a drop
thefever is a jewel in the roughthefever is a jewel in the roughthefever is a jewel in the rough
6x9's in the rear. You have to modify it so the magnet will clear the bars in the trunk.
Old Oct 15, 2006
Technical Assistant
What part of my statement did you miss.
1. I have a sedan
2. I checked, and there is NO room for the 6x9s to go there...there would need to be some serious cuttingg and stuff to make a hole for them.
Old Oct 15, 2006
juanotejano's Avatar
juanotejano is an unknown quantity at this point
1. I have a sedan
Then it sounds like you have your answer, so leave now if your gonna just gonna make stupid posts that you either already know the answer for or could search and find in 2 sec.
Old Oct 15, 2006
009's Avatar
009
009 is an unknown quantity at this point
i also have a 2001 lx sedan, and i fit 6.5's in the front and rear deck. this is the set i used for the fronts Polk Component Set because it comes with tweeters that you can mount on the sail panels (and it sounds niice). for the rear i used Polk 6.5's. they're basically just another set of 6.5's but without the tweeters. of course an amp will get the most out of this setup.
btw i also had the 6x9 headache. my alpine 6.x9's wouldnt fit without cutting and i was not about to do that.
Old Oct 15, 2006
thefever's Avatar
I need a drop
My bad, I missed that part. http://www.crutchfield.com/S-OMAQvt9....asp?g=400&l=E
Crutchfield is your best friend.
Old Oct 15, 2006
manahoonie's Avatar
sedan...6.5s all the way around.
you need a bracket to make the fronts fit properly. I am not sure of the site that has them, but you may be able to get it at Circuit City as well.
depending on the ACTUAL size of the 6.5s you get for the rear, some modification may be needed. The ones I got (Clarion) don't allow the holes to reach the edges of the metal all the way around, so I made little brackets that allow them to connect. Some other 6.5s i've heard are too big for the rear holes, so people have to modify the other way sometimes!
Old Oct 15, 2006
deciuss's Avatar
Boosted Auto
had the same issue when i had my rears installed this week, the computer says its 6x9's but its not but hey i saved some cash by not having to buy 6x9's
Old Oct 15, 2006
Sedan = 6.5 All Around
Old Oct 15, 2006
thatsmrgimp2u's Avatar
An elephant.... with stamps for hands.
thatsmrgimp2u is an unknown quantity at this point
I had to use an inch spacer in the front for my 6.5's, ten bucks at ccity, as far as the rear goes no modification should be necessary other than the holes not linning up perfectly, the bars wont be a problem as long as you stick with the polks. Actually CCity dropped infinity, so i dont think they sell anything that will be a problem.
Old Oct 15, 2006
Technical Assistant
I DID search, and found nothing. And I dont know the answer to it. Someone siad that the fronts are 5 1/4, and circuit city said they are 6.5 all around. thats why i asked
Old Oct 15, 2006
82801BA's Avatar
82801BA is an unknown quantity at this point
SEDAN (through research and personal experience)
Rear = 6.5" standard
Front, depends on how you want it to be installed....
1. You want to make sure the speaker stay at near the surface = 6.0" or smaller, with a 155mm diameter, at least 53mm thick spacer.
2. You don't mind the speaker stay deep inside and you don't get direct raidation from the speaker = 6.5" with undersized magnet, install directly on the steel door panel.
Anything else would cause your plastic door not closing properly. ie. installing a 6.5" speaker with 1" standard 6.5" speacer can cause the front of the door panel to pop out.
The best way to do is to take out the factory speaker and measure the thickness and the diameter. It will ensure that you have ALL the sound that you paid for.
Old Oct 16, 2006
Technical Assistant
Sounds like a lot fo wrok for jensens
Old Oct 16, 2006
genx_7's Avatar
genx_7 is an unknown quantity at this point
Go to crutchfield.com. See which ones fit your car. You will see that there are a couple 6x9 speakers that fit the rear, but also ones that don't for the coupe. For the sedan, I don't see any 6x9. Also you will see that not all 6.5will fit in the front and rear. So basically,don't go strictly by what size the speakers are.
Old Oct 16, 2006
009's Avatar
009
my polk's didn't clear either my rear deck or my front doors. i had to get creative with my friend the razor blade. after a little trimming of the inside plastic everything sat flush....but with no sound damping they are prone to annoying rattles.
Old Oct 16, 2006
You have MOMO's or db's?
Old Oct 16, 2006
009's Avatar
009
db's
Old Oct 16, 2006
Hmmm, ive never run into an app that the db's fit poorley, ill have to keep that in mind.
Old Oct 16, 2006
Technical Assistant
I wont be replacing my speaks...turns out the rattle wasnt it being blown, but just the back one ratting a bit..when i push it up or pull it down from the drunk it stops...il just put some carsboard or something there to fillt he gap
Old Oct 16, 2006
Nothing like the sound of 20watts of pure pioneer power
Old Jan 17, 2007
rs4duke81's Avatar
rs4duke81 is an unknown quantity at this point
does anyone know if it is possible to put the momo 6.5 components in the front? if so will it require modification?
Old Jan 17, 2007
rs4duke81's Avatar
any help would be greatly appreciated, thanks
UltraHDGames
Jun 8, 2016 05:16 PM
68camerors
Sep 24, 2015 06:18 PM
Gsxtacy
Sep 12, 2015 01:09 AM
