Problem with my brand new Deck
Old Sep 17, 2006
vietfob714's Avatar
vietfob714 is an unknown quantity at this point
Just got a Pioneer Premier DEH-P780MP ... installed it and there is major engine whine. Not the regular one... you can barely hear the music loud. Anybody have any idea ? Its going to a rockford 4ch...
forgot to mention i had a deh-p680mp in it already and had no problems...just upgraded and had this problem
Last edited by vietfob714; Sep 17, 2006 at 01:39 AM. Reason: Automerged Doublepost
Old Sep 17, 2006
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
do you have a amp hooked up or speakers ? and whats the wattage on you pioneer? what gauge wires? gotta mention these things
Old Sep 17, 2006
vietfob714's Avatar
I did mention that I had it hooked up to a rockford 4 ch w/ 16 awg wire. I had no problem with the 680 just with the 780
Old Sep 17, 2006
ohsnapsjay08's Avatar
ohsnapsjay08 will become famous soon enough
hmmm i got that whining sound before too but only happened once, and prolly around next week iam getting a Pioneer P780 (same as yours) but the good thing is i already hooked up gearbox's custom made grounding.. definitely seen improvement... lights got brighter, cooler aircondition.. and what not.
Old Sep 17, 2006
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Dude I seriously hope you didn't hook the amp to the battery with that 16 gauge. Most likely the engine whine is either a ground loop or power noise.
1. GROUND LOOP
If you're not grounding everything properly, or you have some sort of loop in your wiring, it'll cause a really loud whining noise in your system. It's a long process but go back and check all your ground connections to make sure they're tight and secure. Also try grounding eveything to the same place if possible. And PLEASE make sure you scrape any paint off the grounding areas so it's a nice clean contact point.
2. POWER NOISE
Not sure what it's called, but it happens when you run the power wire too close to your speaker wires. Another characteristic of this is it gets louder when you rev your engine because your alternator spools and your battery puts out more power.....or some **** like that. Try running your power wires away, far away from your speaker wires.
Old Sep 17, 2006
skipbarber's Avatar
the pricier pioneers also require noise filters on the constant 12v+ feed wire..
Old Sep 17, 2006
DeX's Avatar
DeX
Canadian, Eh!
In that case, you can pick those up from Radio Shack for $15.
Old Sep 17, 2006
phuviano's Avatar
Slowest 7thgen in the GTA
who told you that bunch of crap???
I have the 9800bt, and I have no noises at all. I don't have any noise filters.
Old Sep 17, 2006
vietfob714's Avatar
The amp is hooked up to the battery with 8 awg. That has nothing to do with it. I had a 680mp hooked up to everything and it worked fine... i just switched the 780mp and i got the noise. Everything else stayed the same... any clues?
Old Sep 24, 2006
skipbarber's Avatar
i installed them for a living for 3+ years and most pioneers come with inline noise filters on the constant. my avic-n1, n2, and p860mp all came with inline filters.
Old Sep 24, 2006
i noticed that too, like a lil control box. but it should come with the harness, no? idk, anyway its prolly a grounding problem. ive never had alt whine and dont think i ever will. try regrounding the HU to a different location.
Old Sep 25, 2006
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
I would run new power to the ignition harness and also a new ground wire to a paint-free piece of metal. Also, how is the ground at the amplifier? I hope it's not loose or corroded, take a look at that.
If all that doesn't help you may think about trying to bench test the deck, I don't know what kind of equipment you have access to so that may or may not be difficult. In my experience I have seen a number of Pioneer decks that had unusual noise problems which were only cured upon replacement of the deck. Best of luck to you.
Old Oct 2, 2006
vietfob714's Avatar
Just got it back from warranty. Just defective but they did tell me to becareful with the new decks because their rcas are very sensitive. So dont plug them in and out while the deck is on.
Old Oct 2, 2006
Black-EM2's Avatar
Black-EM2 is an unknown quantity at this point
make sure your rca wires are not ran along side of your power wire!
Old Oct 2, 2006
vietfob714's Avatar
its not. i ran the system inside the car already and had a deck... i just got a new deck and then it occured. I got it back from warranty and installed it already. Works fine now.
Old Oct 2, 2006
4Saris's Avatar
4Saris is an unknown quantity at this point
I had major whine until I ran my radio ground to the same location of my amp ground.
Old Oct 5, 2006
flyguy050's Avatar
flyguy050 is an unknown quantity at this point
I dont understand why one head unit would do that and the other didnt, but i had a similar problem until i got an SGLI ground loop isolator made by stinger, problem solved
CarStuff
Dec 6, 2020 12:52 PM
mohawkboom
67
Aug 25, 2015 12:28 AM
crowtoo
May 11, 2015 06:50 PM
Mokushi
Nov 1, 2001 02:40 PM
