Where to mount my amp?
Old Sep 12, 2006
SDhondarider's Avatar
SDhondarider will become famous soon enoughSDhondarider will become famous soon enough
I just installed my system last night, and since it was late we didn't finish mounting the amp anywhere...where should I mount it???
I wanted to put it into the folding rear seat but I opened up the cushion see if there was anywhere to screw into with the MDF I have as a mount...and there is no metal to mount on. I'm thinking I should mount it on the fender or in the little gap behind the fender....
Any help or pics of where yuou guys mounted your amps would be greatly appreciated. Thanks in advance!
Old Sep 12, 2006
texascivic2k1's Avatar
THE LONE STAR STATE
texascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of light
Here this link might help you...
http://www.7thgencivic.com/forums/sh...d.php?t=275611
Old Sep 25, 2006
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
In my car I unzipped the cover to the larger fold down seat to reveal a network of thin intersecting metal bars. If I remember correctly the bars run horizontally. What I did was cut strips of 1/2" MDF that were just slightly less wide than the distance between two of the parallel bars. I then put in one strip at a time between the bottom two bars, turned it 90 degrees and pushed it up and off to the side. Each successive piece is put to next to the last one. I got about 4 strips in there and was able to mount an amp and a cap this way. It worked very well, I'll see if I can find any pictures of it.
Old Sep 26, 2006
I already mounted it a long time ago so don't worry about the pics.
/thread.
h4ldol
Apr 24, 2017 08:16 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
UltraHDGames
Jun 8, 2016 05:16 PM
jackoncruzpr
Sep 29, 2015 07:59 PM
redcloud
Sep 7, 2015 01:45 PM
