quick question where to run the power wires
Old Aug 23, 2006
civic05acer's Avatar
civic05acer has a spectacular aura aboutcivic05acer has a spectacular aura aboutcivic05acer has a spectacular aura about
yea im really new at this audio entertainment stuff. cuz i didnt really think i was gonna put heavy subs in my car but i got some for free and i looks sick so i guess ill hook it up.
first where do people usually run the 12 volt + to the amp? do they go under the car to the amp in the trunk or inside the car through the firewall if so where where?
also what is the basic setup i think its this but correst me if im wrong:
rca stero ouput to amp input, sterio wire to amp (to turn on amp), then 12+ to amp and amp ground. then amp + and -to subs with speaker wire. is this right?
Old Aug 23, 2006
AceBeezy's Avatar
AceBeezy is an unknown quantity at this point
hehe u shoulda did that down here
Old Aug 23, 2006
should but didnt have the time. team ace rep
Old Aug 23, 2006
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
do some searching on this site for install info..you'll be able to find lots of posts...
Old Aug 23, 2006
run it through the firewall above the brake pedal, then through the sides and under carpet. run power wires on one side and speaker/rca on the other side.
Old Aug 24, 2006
AceBeezy's Avatar
hey wassup... call up my brother and he'll help you out
Old Aug 24, 2006
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Not through the sides, it's impossible to get any wires around the trunk release. Especially a power wire.
Remove the back seat and run it under the carpet, you'll be much happier. I have my power wire running down the passenger side now with all the speaker wire, I get feedback like a ****.
Old Aug 24, 2006
mkuenzi's Avatar
mkuenzi is an unknown quantity at this point
I just did my install. Run the power wire on the passenger side of the car. If you take off the kick panel and the side panel (after unbolting the seat belt bar) , then peel back the carpet under the glove box and you should see a big bundle of wires. I was actually able to cut alittle more of a slit into the gasket around the wires and stuck part of a clothes hanger into it, I then stuck the hanger through the 4 gauge power wire i was using and taped around it with electrical tape. Then I stuck the hanger in the hole, went under the hood and yanked on the hanger and out came the wire.
And I really dont understand what people are saying when they say they cant get their wires past the trunk release. My wires just go under the side panel, not even coming near the release levers.
Old Aug 24, 2006
DeX's Avatar
DeX
Canadian, Eh!
This thing.
You have to run the wire around it.
Old Aug 24, 2006
you can run it around that below the door sills at least on the 02.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
pincookie1
May 4, 2015 12:22 PM
bsmiley
Apr 27, 2015 01:27 PM
NukeSilo
Nov 20, 2001 05:17 PM
MooCoW
Nov 9, 2001 05:22 PM
