0.5 ohm stable amps??
Old Aug 13, 2006
Bryan35613's Avatar
Bryan35613 is an unknown quantity at this point
Right now im in the process of selling my existing system and starting from scratch except for the wiring...im thinking about getting 2 of the pioneer TS-W3002SPL and if wired right would give me a .5 ohm load and i was wondering if anyone knows any really good amps that are .5 ohms stable because if not i can always get the TS-W3004SPL version which is 4 ohms per voice coil as opposed to 2 but i would rather the 2 ohm per coil version simply for the ability to run them at higher wattage...but anyways if any of yall know some good amps please tell me..
Old Aug 17, 2006
josby's Avatar
josby is an unknown quantity at this point
I think rule changes (and/or the popularity of DVC subs) have sent low-ohm amps the way of the dodo bird. Companies like Soundstream and Lanzar that used to brag about 1/2 or 1/4 ohm stability now offer nothing lower than 1 ohm.
You could get an older used one of those, but I think you'd be better off getting the two dual-4 ohm subs to give you a 1 ohm load. There's no inherent advantage to a .5 ohm load...yes, an amp that's stable into .5 ohm will probably put out more wattage into that load than it will into 1 ohm, but given the current rarity of .5 ohm-stable amps and the near-ubiquity of 1 ohm-stable amps, the selection and $/watt will be way better with a 1 ohm amp.
Old Aug 17, 2006
eye_see_you's Avatar
let the devil out
I woudl have to agree most amps these days do not go below 1 ohm to include the huge Hifonics amps, soundstream, zapco etc etc.. I woudl say go with the two in dual 4 ohm or get 3 of the 2 ohm subs
Old Aug 17, 2006
civic01vtec's Avatar
My xtant amp is stable at .5 ohm.
Old Aug 27, 2006
darklegacy540's Avatar
darklegacy540 is on a distinguished road
I can't really think of a big long list since a good portion of them were previously named.. however, nobody has mentioned Orion yet. They are now owned by DEI but hey.. it's still good stuff.
Old Aug 28, 2006
spudracer326's Avatar
spudracer326 is an unknown quantity at this point
incriminator audio 20.1....check out caraudio.com...there is a guy selling a bunch of them for 500 shipped each....for the money you wot get a more stable amp in that low of an ohm load...they are(so ive been told)stable to
.08ohm daily...at .5 ohms they will do a little less then 3k watts....they are way underated.....
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
JetsterDajet
52
May 8, 2016 12:11 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
