Agravation....
Old Jul 3, 2006
thatsmrgimp2u's Avatar
An elephant.... with stamps for hands.
thatsmrgimp2u is an unknown quantity at this point
Agravation....
I just put in a pair of polk momo's in the front of my car, a 12" Kicker CompVR, and a Kicker 700watt 5h amp. When i turn the car all the way on and get the engine running i can here noise coming out of the speakers even when the volume on my deck is at zero. Also, the sub motorboats, pulsates, again at zero volume. Ive played with the gain and crossovers on the amp, ive tried new RCA's, i melted the ground wire for my LED fuse holder cleaning up the power wires a bit, I have tried three different ground locations. I just dont know what the frick to do anymore. Help would be greatly appreciated.
Oh and if it was needed to know, Power and Sub RCA's are run on the passenger side, and 4ch RCA's and speaker wire aer run on the left side.
Im using monter cable speaker wire and Tsunami Power and RCA's.
Thanks in advance.
Old Jul 3, 2006
hondakorn2's Avatar
hondakorn2 is an unknown quantity at this point
I have this same problem......
Old Jul 3, 2006
same amp?
Old Jul 3, 2006
hondakorn2's Avatar
kenwood amp..I have been told by others that its the headunit....its been driving me insane too.....when I hit a bump in the road it would do that also.
Old Jul 3, 2006
m3mo15's Avatar
m3mo15 is an unknown quantity at this point
Post
Thanks in advance.
my brother had a similar problem, ive always been told to wire power cables seperated from any speaker wires or RCA's, the electrical current may interfere, try wiring the power cable and the RCA's seperate from each other.
Old Jul 3, 2006
I ran a test RCA OUTSIDE of the car to see if that was the issue, and it isnt =(
Old Jul 3, 2006
m3mo15's Avatar
well i called my friend he works in Florida Sounds here in miami, he told me that its a bad RCA cable, since u said u already changed it, i dont know what else to tell you.
Old Jul 3, 2006
05CoupeCivic's Avatar
05CoupeCivic is an unknown quantity at this point
Um dude, run every RCA down the same side, then run the power and remote wires down the opposite side and tell me what happends.
Old Jul 3, 2006
AlienX's Avatar
AlienX will become famous soon enough
does this happen with the engine on, off, or both ? If ON, then it's prob alternator whine... not much you can do about that.
Old Jul 4, 2006
ON only, tried new RCA's everywhere.... still does it =(. IM gonna try a new headunit see if that helps, ill keep you guys updated, maybe it will help someone in the future.
Old Jul 4, 2006
susuking's Avatar
susuking is on a distinguished road
have u tried a ground loop isolator?
Old Jul 4, 2006
jay47's Avatar
jay47 is an unknown quantity at this point
I did have the same problem too, so I bought a ground loop isolator (GLI) and it fixed it. When I would turn the car off, my subs would turn on full power for about 5 seconds while the amp was still on. It was really strange, but then one day it just quit. I took off the GLI and it worked fine, almost like it was haunted.
Old Jul 4, 2006
Tried a GLI and it removed all the low frequency from my sub. I shortened my ground wire to about 11" and i ran a seperate ground for my radio (apparently the factory ground isnt terrific) It helped but the problem isnt compleletly solved. Stil havent tried a new deck but im pretty sure thats what it is. Ive eliminated every other variable. I can live with it as long as the gains are turned down i suppose. 8volt preouts dont take much. Ill repost if i ever get off my lazy **** and swap decks.
Old Jul 17, 2006
4Saris's Avatar
4Saris is an unknown quantity at this point
One of three problems for the alternator whine:
1- Most common is the running of the power wire along the same side as the RCA cable.
2- Bad grounds or insufficient gauge of ground wire leading.
3- Try grounding your amp and radio to the same location. I had to run mine to the back area where the other two amps were grounded to eliminate the whine.
Old Jul 17, 2006
BlackKnight008's Avatar
420 Member
BlackKnight008 has a spectacular aura aboutBlackKnight008 has a spectacular aura aboutBlackKnight008 has a spectacular aura about
id switch the head unit, I had to do it to run my system at its potential
Old Jul 18, 2006
WhiteRabbit's Avatar
you can filter the power wire, and youll eliminate the problem.
an inductor on the constant 12 volt side of things should do it.
or you can leave the ground loop isolator in there, too.
