Adding tweeters to non-component system?
Old Jun 30, 2006
scrimp's Avatar
scrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of light
Is this possible to do? I see that some places sell tweeters separately. I wanna buy some EX sail panels and mod the tweeters to fit inside there.
Im lookin to get some infinity tweeters and I did some searching and found that with some slight modding to the sail panels they will fit. My question is...is it possible to do this to a non-component system?
Right now....i have stock 6x9s and infinity 6002i in the doors.
Im pretty sure I need to crossovers, right? I see these bass blockers, are those necessary? Thanks
Old Jul 1, 2006
Derrik's Avatar
Derrik is an unknown quantity at this point
yes you will need a crossover i belive u can buy those seperate too... bass blocker i dont think so becuase the crossover will filter it out for you i bleive so anyone correct me if im wrong.
Old Jul 1, 2006
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
Yeah, you can add tweeters to your current setup. Just make sure you wire the front channel speakers in series with the tweeters. Those bass blockers should work too, it is pretty much just a crossover.
Old Jul 1, 2006
skipbarber's Avatar
it's going to sound too bright. the 6002i's have an integrated tweet. Id sell them and get the component system instead. those include the woofer with a seperate tweeter and a matched crossover. it will sound better if the equipment you use is engineered to work together.
Old Jul 1, 2006
i did exactly what you're planning. i have 6.5 infinity 2 way in the doors and separate tweeters in the sail panel. i just did a surface mount on my sedan. looks great, sounds awesome. I have them wired to deck power and they are pointed inward. The 4 speakers are running off the 4 channel amp and the front door speaker tweeters are turned to the floor. sounds perfect imo.
Old Jul 2, 2006
Nasdurus's Avatar
Nasdurus is an unknown quantity at this point
Very easy. just make sure the tweeters you buy come with a crossover. You won't need a bassblocker if it comes with a crossover. and just wire them in and you've just made your own component
Old Jul 2, 2006
most every decent tweeter comes with a small xover/bass blocker. i know the infinity does for sure.
Old Jul 3, 2006
scrimp's Avatar
Cool, thanx guys for all the info! Ill be back if I have more questions
mjdiaz89
Jun 21, 2016 09:26 PM
carid
Nov 7, 2015 01:46 AM
andyandyy
Aug 4, 2015 06:37 PM
shaejb15
Jul 27, 2015 03:48 PM
