Headunit wiring question
Old May 25, 2006
spilot's Avatar
spilot will become famous soon enoughspilot will become famous soon enough
My HU does not have the blue "power antena" wire, and my aftermarket harness does. I've done some search here, and got numerous answers...My HU has the blue/white "remote" wire that goes to my amp, and has a tag sign that says "the is not the wire for the power supply"...some folks here have suggested to to make a 3-way and connect power supliy wire from my harness to a remote white/bue + amplifier remote. Should this be ok?
others suggest to hook it up to the factory green/yellow, but on my 01 civic car harness, the green/yellow is driver/front (+) speaker, so i'm a bit confused...
Old May 25, 2006
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
just dont use it.. cap it off
Old May 25, 2006
ajhdragon's Avatar
7thgens official a$$hole
don;t use the power antenna wire, why? because we don't have them. just cap it.
Old May 25, 2006
spilot's Avatar
apparently the radio reception isn't going to be as good, because we do have an antenna...
Old May 25, 2006
ajhdragon's Avatar
we have an antenna but not a power antenna
Old May 25, 2006
05reverb's Avatar
05reverb is an unknown quantity at this point
we dont have a power antenna that goes up and down, but we still need to power that wire cause we have a antenna booster in the back right of our cars and it needs power to better the reception. just connect the power antenna wire to the remote wire, the booster will get power when the HU is on (instead of only when radio is on).
Old May 25, 2006
spilot's Avatar
and...where do we connect it hahaha?
Old May 25, 2006
05reverb's Avatar
connect the blue wire from your headunit to the power antenna wire on the aftermarket harness. when the headunit turns on, it will power the power antenna wire wich goes to the back of our car to the antenna booster.
Old May 25, 2006
spilot's Avatar
that's the thing, my headunit does not have the blue wire, just the remote (blue/white)...that's the whole catch
Old May 25, 2006
05reverb's Avatar
i know your headunit doesn't have the blue power antenna wire, you don't need it, connect it with the blue/white remote wire instead. They are the same, exept the remote wire is always on when the headunit is on, but the power antenna wire is only on when the radio is selected. It doesn't matter if you connect it to the remote wire instead, it just means that it the booster will be on anytime the headunit is on.
Old May 25, 2006
spilot's Avatar
doesn't sound like a big problem to me then...thanks for the answer!
ps. sorry, i missed your post before that where you explained what to do. thanks for being patient.
Old May 25, 2006
05reverb's Avatar
no problem, anytime
pincookie1
May 4, 2015 12:22 PM
LJ
Dec 10, 2001 10:48 AM
viper775
Dec 9, 2001 10:52 PM
Foom
Dec 6, 2001 01:11 PM
