Need suggestions for a new amp..
Old Mar 26, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
Yeah so i'm in the market for a new amp.
I'm currently running:
Nakamichi SP-W1200D
Description: SUBWOOFER SPECIFICATIONS Diameter: 12" 305mm Sensitivity: 88dB Power Handling: Watts RMS: 450 Watts Watts Peak: 650 Watts Frequency Response: 20Hz-500Hz Nominal Impedance: 2 x 6 Ohms Cone Material: Pulped Paper Basket Material: Aluminum Surround Material: 2.25" Rubber Spider Material: Nomex Magnet Weight: 120oz. Voice Coil: Dual Free-Air Resonance (Fs): 28.15Hz Mechanical Dampening (Qms): 6.297 Electrical Dampening (Qes): .742 Total System Dampening (Qts): .663 Voice Coil DC Resistance (Re): 5.6 Ohms (Dual) Equivalent Acoustic Volume (Vas): 74.504 Liters Effective Diaphragm Area (Sd): 49.087 sq. meter Linear Coil Excursion (Xmax): 12.5mm Half Space Output Level (SPL): 88dB Energy Bandwidth Product (EBP): 43 Mass of the Moving System (Mms): 114.656 grams
Ultimate Audio TA2300 (2x150 Watts)
My sub is wired like so..
which meens im running at 3 ohms, correct? So by using the Ultimate amp I am not able to achieve maximum power only being at 3 ohms.
I see most ratings on amps are in 4 and 2 ohm configurations.. Any amps that I could get that would let me push 400 rms @ 4 or 3 ohms?
Its been years since I messed with any of this technical stuff so correct my where I'm wrong please..
Let's here your ideas..
Old Mar 27, 2006
luvvegas777's Avatar
banned from avatar useage
luvvegas777 is an unknown quantity at this point
when you bridge an amp it will see half of the impedence, which will be 1.5 ohms, however impedence always changes as a speaker moves. there are so many amps on the market, how much $ are you willing to spend.
Old Mar 27, 2006
XSRCivic's Avatar
If possible I'd like to stay in the $200-$300 range.
Old Mar 27, 2006
kenwood kac 7202, kenwood 9102d good power for the money
Old Mar 29, 2006
Mystic3030's Avatar
Yup, i'm an A$$hole.
JL Audio 500/1 puts out 500 watts at 1-4 ohm.
UltraHDGames
Jun 8, 2016 05:16 PM
solarpunk70
Apr 12, 2016 11:43 AM
juicetayne
Sep 30, 2015 11:02 AM
anubis62
Sep 27, 2015 12:56 AM
J-Fly
Sep 10, 2015 08:39 PM
