Good Ground Under Hood
Old Mar 25, 2006
WhiteHalf's Avatar
WhiteHalf is an unknown quantity at this point
Sry for the noob question, but I bought an HID conversion kit, and have it all wired up into TYC's.
Now I kinda want to test the kit to see if I set it up properly, wiring etc BUT on the wire harness, there is a red wire and black wire.
So the red to the battery, of course
And the black to a ground
Now, the main car ground is kinda attached to where the hood latch is. Would it be ok if I simply attached this gound to that same screw ?
Also, if it isn't safe and I choose another screw anywhere - I heard you should sand down the paint, so that the ground is touching bare metal - is this something I should do ?
Thx for the help.
Old Mar 25, 2006
05CoupeCivic's Avatar
05CoupeCivic is an unknown quantity at this point
i know for sure sand down the paint, and i assume that you can ground it to any screw, much like an amp..
Old Mar 25, 2006
WhiteHalf's Avatar
Civic my reason is that I only want to take it out and test it, I just dont want to have to grind down to the paint, just for the test.
Thats why I was wondering if I can attach it to the main ground whre the car already has a grounding wire.
Old Mar 25, 2006
iLLesTCivic's Avatar
iLLesTCivic is an unknown quantity at this point
put it to the battery ground sherlock
Old Mar 26, 2006
WhiteHalf's Avatar
really ? I didn't think I was supposed to do that ... Are you sure that is ok ?
Old Mar 26, 2006
red_sun's Avatar
Boost is so good make you wanna slap ya mamma
red_sun is on a distinguished road
If you going to just test it you can put it on any part of the chassis you don't even need to sand you just sand it down to bare metal for a better connection.
Old Mar 26, 2006
free_refil's Avatar
free_refil will become famous soon enoughfree_refil will become famous soon enough
You'll need to sand it down if it's got paint on it. Don't forget that just for testing, you can use the wires directly on the battery terminals. For the final install, don't connect the power wire to the battery unless you want the HID's on all the time! I dunno how your kit works, but you should be using a relay and tap into the + wire of your low beams existing wire socket. Then the relay will need a + tap from your battery and of course a good solid ground. Where your grounding strap is connected from the engine is good if that's an easy location to reach. Otherwise so is your - terminal on the battery.
Old Mar 26, 2006
WhiteHalf's Avatar
Yah ... I wish I knew how to post pics up .. cause I got a perfect one.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
civic1316
May 29, 2015 05:13 PM
autowill
May 15, 2015 11:36 AM
superstanko
Apr 28, 2015 04:38 AM
