help mounting components?
jsut got xenon 5.0 component set
they are convertible. i can attach the tweeters straight on. but would like to install them else where. sail panel maybe?
they didnt come with any mounting bracket sor anythigns so im confused on how to mount them.. i mean cut a hole and shove them in. but aside form that.. :S :|
help guys!
help guys!
ic an take pics but im sure u know wut they look like
the back of the tweet is a internal thread witht he wires coming down it. but i have no adaptor for the to mount so im not sure how to even screw or hold the damn things to a mount lol
confused
i was thinking sail panels but my mirrors are not power so i have the *** in the way. maybe jsut sink them into the door panels?
what have i got for options? the dash for a more forward sound?
confused
7thgens official a$$hole
I would reccommend maybe fiberglassing over your stock mirror covers or something. ot that extent. or if you have confidence in makeing a clean cut in your doors go for it. I always used this super stong hot glue and mixed it with superglue to get the tweeters to stick to the stapping. Just don't breath it in because it is toxix when you mix the 2 glues. as for connecting just extend the wires.
If you don't want to run them as coax and want to move the tweeters you have a few options. You can mount them in the door and make your own strapping to hold them in. You can mount them in the sail panel, if you have a coupe you can get the oem tweeter pods. However you would have to take the mirror adjusting stick out and would ahve to adjust the mirrors by hand unless you installed power mirrors. Or you could put them in the A-pillars. Can you aim the tweeters when they are running as coax?
aim no. the stock fin idea seems best
extending wires etc is fine. im just confused on how to mount the fracking things. sigh . lol.
a piler i though of. maybe mounting them into the door panel.
where would one aquire the needed replacement sail panels for my coupe in black?
you can get them from your local honda dealer or try majestic honda. You need the ones from an ex. Another option you could try is using back strapping to mount them in front of the woofer. Thay way you can aim them.
http://www.hondaautomotiveparts.com/...atcgry5=MIRROR
I dont know how to post active links.. but anyway #7 I think
you probably want to call them to check just to make sure.
hmm ok i figrued otu how the damn things are suppose to hold into the hole.
ill contact honda here tomorow and find out ift hey can get me the sail panels.
need to get the damn door off. bloody cranks lol.
once i do that im going to look at them to see if i can mount the cross overs inside the door... the PG cross over is a single unit but the pcb is designed to break in half but then i need to see if its possible to mount int he door or not
jackoncruzpr
Sep 29, 2015 07:59 PM
ZoSoIV
Sep 17, 2015 07:17 PM
FistRock
Sep 4, 2015 08:00 PM
