HU Volts ?
Old Feb 20, 2002
Cypher's Avatar
Cypher is an unknown quantity at this point
HU Volts ?
how much volts does the stock tape player put out ?
Old Feb 20, 2002
mohawkboom's Avatar
well 12 Wrms.. 4 ohm resistance.. 3 volts or so.. But if you're going by Pre-out Voltage.. 0.. Stock HU's do not have RCA outputs.
Old Feb 27, 2002
Rebew1's Avatar
Rebew1 is an unknown quantity at this point
If you are talking about power(which is measured in watts)it is around what mohawk said. But that is not how you figure out voltage of the output. If you take the above stated numbers your voltage will actually be 6.928 volts.
Old Feb 27, 2002
mohawkboom's Avatar
True.. I stand corrected.. lol.. also that's a 4phm reactive load so Impedance is higher..oops
Skunkone
Sep 24, 2015 04:38 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
JetsterDajet
Aug 16, 2015 01:56 PM
jnissen
Aug 9, 2015 05:34 PM
