require direction
Old Feb 23, 2006
civrunainfnluva's Avatar
civrunainfnluva is an unknown quantity at this point
require direction
i bought a q-logic dual box with 2 infinity subs...12 inches...the subs fit, but how do i wire the sub to the box? the wires from the box dont seem to fit into the sub terminals....help?
Old Feb 23, 2006
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
r the wires bare coming from the box (no connecters) normally all you have to do is either put a female clip on the wire and slide it over the post of the sub. Or you have to push the terminal down on the sub and then you just slide the wire in.
Go 2 Google and search sub install and there should b a pic of what you need to do somewhere. Its really easy. Or just have a friend come over cuz one of them should know to
Old Feb 23, 2006
the terminals unscrew to a certain point and there is a hole. but the wires have a bare end with like a flattened end. it seems like some sort of connector but it is too wide for the hole
Old Feb 23, 2006
LowSky's Avatar
I spend way too much time on this website
LowSky is an unknown quantity at this point
cut the connector off then strip the wire so you have about an inch of bare wire then put wire into terminal hole the screw down the terminal... your done
please rep
Old Feb 23, 2006
thanks
Bruce2
Sep 21, 2015 08:01 PM
