MTX SUBS AND AMP
Old Feb 17, 2002
SiLvEr2001CiViC's Avatar
SiLvEr2001CiViC is an unknown quantity at this point
MTX SUBS AND AMP
WHAT DO U THINK ABOUT MTX T8124 or ALPINE TYPE R IS BETTER IN SIZES 12 INCH
and also the amp
mtx thunder 81000d or alpine mrv 1507
i was think on gettin the mtx system but im not sure about the subs
maybe i should get mtx amp and 2 type rs
Old Feb 18, 2002
NitehawkVTEC's Avatar
NitehawkVTEC is an unknown quantity at this point
well, i have the above sub, and I can tell you. It doesn't work, I've only had it for 2 weeks, and i've had it exchanged once already. and right now it doesn't work. haha. it does pound thou, definatly is better than a Type-R. how about Phoenix Gold XMAX? should be better than Type-R. for the amps, get a phoenix gold too!
Old Feb 18, 2002
mohawkboom's Avatar
Alpine Type R sub, MTX amp..the Alpine amps are not impressive in any ways Also the MTX is a class D amp and will be less strain on your electrical system.
Cheers
Mohawk
Old Feb 18, 2002
but do u think that those amps are good enough for 2 (12INCH) type rs
which one is better
Old Feb 19, 2002
mohawkboom's Avatar
Silver. there's no such thing as an amp not being enough for a sub.. Unless it's an all out SPL subs with very stiff suspension. Even an MTX6500D would be MORE than enough. They put out close to 900Wrms... If you're planning to compete then yeah get an MTX81000D.. Otherwise it'll be more than your ears ccan ever handle. I'm running 450Wrms to a pair of Planet Audio p12DVC Subs(winter setup) and I'm still hitting over 135 DB's..which in plain english is 15 Decibels more than your ears can take without damage.
More power doesn't mean better if it's just for yourself.
Cheers
Mohawk
Old Feb 20, 2002
Slammed2k1's Avatar
Slammed2k1 is an unknown quantity at this point
The 8100d is overkill and will blow those subs, the 6500d is the match for 2 8000's.
Chris
Old Feb 20, 2002
if your running 8000s be sure to not over drive them, i think the Rating of 400RMS on them is a little optimistic myself. as I went through 2 of them in 5 days. I was feeding it 500watts, but it should have been nice clean power. Phoenix gold amp running 4 ohm. and i wasn't even pounding em that hard.
GolNat
Nov 27, 2018 03:32 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
UltraHDGames
Jun 8, 2016 05:16 PM
General DIY
Sep 25, 2015 08:02 PM
redcloud
Sep 7, 2015 01:45 PM
