(No More) amp problems
Old Jan 28, 2006
Cptn. Slow's Avatar
Formerly efil on evol on
Cptn. Slow has a spectacular aura aboutCptn. Slow has a spectacular aura aboutCptn. Slow has a spectacular aura about
I purchased a Infinity Reference 7540a amp two weeks ago and attempted to install it today. The amp did not turn on when I started the car after installing it so I tested the ground, 12V source and remote connections with a voltmeter and all of them tested as they should. I do not know of anything to do to correct the situation and believe it might be a problem with the amp. What do you think?
Old Jan 28, 2006
did you hook up the remote turn-on wire from the deck/harness to the amp? thats what turns it on not just having power/ground connected.
Old Jan 28, 2006
Cptn. Slow's Avatar
yeah. I have another amp (sony) and I patched into the remote from the sony for the infinity and the infinity won't turn on. Sony still works
Old Jan 28, 2006
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
Bad amp.
Old Jan 29, 2006
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
as long as the speaker leads arent grounding out some where and you have 12 volts on the remote turn on lead and 12 volt lead, and a good ground, then yeah its the amp.
Old Jan 29, 2006
v8eaterokv6's Avatar
i have a new home do u
what about the fuse is there one on the amp
Old Jan 29, 2006
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
You said you patched it in? As in you physically spliced it? Might not be enough current to work for both. I think the remote turn on lead is only .1 amps or something.
Old Jan 29, 2006
05reverb's Avatar
05reverb is an unknown quantity at this point
I think the remote can handle .5 amps, and is enough to power up 2 amps
Old Jan 29, 2006
Cptn. Slow's Avatar
turns out when I tested my ground with the ohmmeter I was grounding out on the amp and not the wire. So I moved my ground and everything works now. Pics to come
Old Apr 20, 2006
magic_wizard's Avatar
magic_wizard is an unknown quantity at this point
So where is it grounded now?
Old Apr 20, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Pics?
Old Apr 20, 2006
Cptn. Slow's Avatar
man this is OOOLLLDDDD
Old Apr 20, 2006
02BLKCIVIC's Avatar
Hey what the "little box" with the main "power" cord called???
THX!
Old Apr 20, 2006
Cptn. Slow's Avatar
that's a distribution block, allowing me to take one input power source (bottom) and turn it into two output sources (top, one for each amp)
Old Apr 21, 2006
02BLKCIVIC's Avatar
Thanks Evil!
Old Apr 25, 2006
RangerMan's Avatar
RangerMan is a jewel in the roughRangerMan is a jewel in the roughRangerMan is a jewel in the rough
Glad you figured it out. hmm I want that power splitter, I am temporarily using the amp as the splitter, which is probably..bad.
Not to be a stickler, but did you run..the power on same side as RCA's?
Old Apr 25, 2006
02BLKCIVIC's Avatar
I went out to "Audio Express" to find that "exact" one...
lever found it...
If you dont mine evil could you provide a link for us that are interested
roverben
Jan 21, 2019 05:16 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
jackoncruzpr
May 24, 2015 12:24 AM
0100010
Dec 1, 2001 03:27 PM
PimpBot5000
Nov 26, 2001 07:15 PM
