Clifford Matrix RSX 3.5 question
Old Jan 22, 2006
EM2 Bluez's Avatar
EM2 Bluez is an unknown quantity at this point
Question Clifford Matrix RSX 3.5 question
I got this alarm and installed it with the help of a friend. We got everything started and going perfectly but one thing the actuator for the passenger door. I decided that it was an easy enough task to do so and i completed it but with a problem, when i hit lock one door locks other unlocks. Fixed that problem but now when i try to lock or unlock with my remote nothing happens. Its like the alarm is not sending or recieving any signals. I double checked every wire and everything seems okay but still nothing. If any can help please do so thanks in advance.
Old Jan 23, 2006
vipergtsr's Avatar
vipergtsr should not be trustedvipergtsr should not be trustedvipergtsr should not be trustedvipergtsr should not be trusted
How do you have the actuators interfaced with the alarm? Do you have the 2 wires that come off each actuator going to the alarm lock/unlock output(the small gauge green and blue pair)? If so that is your problem. If you are using a standard 2 wire actuator, you need to interface the actuators with 2 SPDT(single pull double throw) relays. Now explaining to you how to wire the relays is a little more difficult, first let me know if this is how you have them interfaced.
Old Jan 23, 2006
EM2 Bluez's Avatar
I have the wires hooked up to the relay module of the alarm. The alarm came with i believe to bosch relays. and thats how i wired them up.
JMKendrick
Sep 16, 2015 06:17 PM
junkyardguy
Sep 2, 2015 06:07 PM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
carid
Aug 8, 2015 05:05 PM
