HU keeps cutting off at high vol.
Old Jan 22, 2006
micks7thgen's Avatar
micks7thgen is an unknown quantity at this point
i have a kenwood KDC-MP425 head unit in my car and if i turn up the stereo past a certain point if the subs hit really hard the unit shuts off and then comes back on. i have stock intereior speakers and i am not sure what is going on. anyone have any clues whats happening?
Old Jan 22, 2006
well lets see its a kenwood so you're prolly overheating it and the protection circuit turns it off. correction is get a better deck.
Old Jan 22, 2006
i dont know if it is overheating cuz it can run for like 30 seconds and do it. but i am planning on buying a new deck it is about 2 years old, time to upgrade to an alpine.
Old Jan 22, 2006
slick's Avatar
that little dude
slick will become famous soon enoughslick will become famous soon enough
Is your car running when this happens, or is this with the engine off?
If its with the engine off, then its due to your amps drawing too much current, current your battery alone can't provide. This is pretty much normal if you have a big amp, been running the system for an extending time with the engine off, or if the battery is crapping out.
If this is occuring with the engine on, it could be that your ground connection is no good. Make sure you have your ground going to metal thats been cleaned off (no paint on the surface or anything crap like that).
Old Jan 22, 2006
it does it when the car is running but it isnt the amp cutting out it is the headunit cutting off. i dont think that it has to do with the ground it has been checked, it worked fantastic up until about 6 months ago. i dont know if the headunit is craping out or not but it is just annoying when i wanna bump it if it hits too hard itll cut off.
Old Jan 22, 2006
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
sounds like a voltage drop is causing it to shut down. If you have access to a DMM, watch the voltage as you turn the volume up on your deck.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
mjdiaz89
Jun 21, 2016 09:26 PM
Martinez8o5
Jul 31, 2015 10:58 PM
mistermenphis22
Jul 13, 2015 04:43 PM
silentz
Jul 9, 2015 08:16 PM
