loud sound coming from sub
Old Jan 19, 2006
jesuisKYLA's Avatar
jesuisKYLA is an unknown quantity at this point
whenever i start my car there is a really loud sound that comes from the sub. last time i changed the ground and it went away but it came back now. the set up is a 12" JL sub that is wired to the stock deck. someone told me that it might be wired to the wrong wire behind the deck. what color is the power wire on the stock deck? thanks.
Old Jan 19, 2006
tarheel365's Avatar
tarheel365 is an unknown quantity at this point
describe the sound...
could be ur ground for the amp?
Old Jan 19, 2006
jesuisKYLA's Avatar
it's just like a really loud bass sound coming from the sub. it only lasts for about a second but gets loud. where did you ground your amp?
Old Jan 20, 2006
tarheel365's Avatar
normally on a bare metal surface^
it'll sound distorted if it was a grounding issue i think....i'm not an expert(at all)
i'm sure someone else can diagnose ur sitiuation better.
Old Jan 20, 2006
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
does it just happen when you turn on your car for a second and then stops? it could be a turn on pop
Old Jan 20, 2006
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
U have the sub hooked up to the deck???!!! R u crazy? Dont u have an amp and a wiring kit?
Is it alt whine? Does it get louder the higher that the engine revs?
In an aftermarket deck the remote turn on wire that goes to the amp is typically blue in the wiring harness
Old Jan 20, 2006
jesuisKYLA's Avatar
no i do have a wiring kit...maybe i should have been more detailed. what color is the remote wire on the stock deck? because i have it hooked up to the stock deck. i'm sure the wires are all correct because i have done this before but this is the first time something like this has happened. i have the rca's running on the opposite side as the power wire. i think it's either the ground or i'm using the wrong wire behind the deck.
Old Jan 20, 2006
Kyle23's Avatar
Its the blue wire like I said in the first post.... how do u have RCA's on a stock deck? Do you have a LOC? (line out converter) If u do then why r u running it up the side of the car? It can just connect to the rear speaker leads.
Add more detail to your posts!!!!!!!!! How are we supposed to assess the situation if u write 2 sentences and leave out key info?
Where is ur amp currently gounded? Common man, we need this info!
PS.
I think that loud bass sound is what the sub is supposed to do... j/k
Old Jan 20, 2006
PS.
no blue wire in the oem harness. All the LOC's we install in my shop are put behind the headunit, remote turn on has to be ran, might as well run rcas as well.
Old Jan 20, 2006
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
i think the problem is that he's using a stock deck....
i think whoever wired up his amp could not find the "remote turn on wire" from the stock deck so they wired 12V directly to teh remote terminal on the amp. this causes the amp to be on all the time and never turns off. when the deck is turned on, he hears a loud "POP" sound.
to get rid of the pop sound, wire the amp's remote terminal to the deck's remote turn on wire(i think the stock deck has one, you just have to figure out which wire it is).
Old Jan 20, 2006
jesuisKYLA's Avatar
there is a piece i bought that you tap it into the speakers and you plug the rca's into that so i ran the rca's all the way up. i have the amp grounded on that metal piece behind the rear seat and i sanded off all the paint. what i'm trying to find out now is what color is the remote wire on the stock deck? i think the problem is that i used a wire that powers on when the car is on but it's the wrong wire.
Old Jan 20, 2006
yellow with a red for <2006
light blue for >2005
or just grab the positive wire for the power plug under the center pod
Old Jan 21, 2006
jesuisKYLA's Avatar
thanks...i'll let you know what happens.
danace99
23
Jun 28, 2015 08:49 AM
Sparty
Nov 15, 2001 04:55 PM
WhosYoDadday85
Bolt-on Engine Performance
Nov 6, 2001 08:06 AM
eX2ooo
Oct 5, 2001 12:19 AM
ernhole1
Aug 2, 2001 11:12 PM
