PS2 / Power Inverter Install - Need Help
yes it does. you'll be fine with the 12 gauge (can handle 20 amps), it is not using more than 15 amps, so if you don't want to do it with relay, just tap in cig lighter 12v + wire and go to the inverter + terminal and put the - terminal on inverter on ground. the 12v cig wire is only like 16 gauge, so if derrik put it in the radio circuit and never had problems, you'll be fine with 12 gauge
DON'T tap the cig lighter for power to the inverter, run it from the battery
sure 12ga is enough for 20 amps, but the 18ga wire on the lighter IS NOT.
a DMM isn't for measuring current other than small amounts. a current clamp is what you need for that.
sure the amp kit might contain some stuff you don't need. but it will contain everything you DO need, all for 10 bucks.
even if it didn't blow the fuse, it's still overloading and really unsafe. it's about creating a fire hazard, not about blowing fuses
yes it WILL overload the lighter circuit, and even if it didn't, it's not the proper way to install
i know, told him to do it with relay, but i think he wants to do it the easiest and cheapest way possible. i had that same power inverter and it had a cig lighter plug with it, so it is safe to be pluged in the lighter or they wouldn't put a cig. plug in the packaging.
Canadian, Eh!
haha you may have your wish with the relay!
I got the inverter installed with the ground wire run and hooked up. I was hooking up the power wire with the add-a-circuit and realized our cars have the mini narrow fuses. The add-a-circuit doesn't fit in any of the holes under the steering wheel!
So is there a smaller add-a-circuit or this is it?
Or.....about the relay......do I have to solder to the pins? I don't have a solder kit which is the main thing holding me back from doing it.
So is there a smaller add-a-circuit or this is it?Or.....about the relay......do I have to solder to the pins? I don't have a solder kit which is the main thing holding me back from doing it.
go get the 12volt relay, and an inline fuse (20 amps), get some 12 gauge, a t-tap (i think you already have that), and then if you need more help, i'll tell you how, but the diagram is pretty easy to understand.
Canadian, Eh!
Originally Posted by 05reverb
i pay 4$ for a relay + harness, so in U.S., probably 2$, really cheap, if thats what you were worrying about.
Canadian, Eh!
Also, I did get a smaller add-a-circuit and I'm experimenting with it to see if it'll work temporarily. But when I plugged it in, the inverter wouldn't turn on. I got the add-a-circuit in the fuse slot for the radio, the inverter's grounded real good, I turn the key, the radio doesn't come on (expected) but the inverter doesn't either. The switch is in the on position. When I move the fuse from the B slot to the A slot in the add-a-circuit and turn the key, the radio works fine. So everything's hooked up right, but for some reason the inverter's not coming on. I tried with all the fuses - 3, 5, 7.5 and 10. None work.
got a multimeter or test light?
i still highly recommend running from the battery, the wire coming into the fusebox isn't very hefty, another 20a of fusing on it could be overkill
in the add acircuit, the first fuse feeds your radio circuit and the second fuse, then second fuse feeds your new circuit, so you need both fuses to make new circuit work
Canadian, Eh!
Which fuse should I be using?
Canadian, Eh!
I put in both fuses, powered up, worked awesome. Then when I take the key out, it's still going....the stereo didn't turn off and the monitor didn't go back into the dash. I couldn't get it to go back in at all, until I flipped the switch on the inverter back to the on position. I thought that was wierd so I left the inverter in the on position and tried it again......now it works perfect, monitor slides back in soon as I shut the car off. So I have to leave the inverter on for some reason and it makes a high pitch noise when I turn off the car. I'll work on that relay over the next week or two.
that high pitch noise is from the inverter, i had the exact same inverter for my ps2, and it made that sound also when powering off, cheap inverter, got that at canadian tire for 30$
