Startled
Old Dec 5, 2005
Steven 89's Avatar
Steven 89 has a little shameless behaviour in the past
Cool Startled
I dont know if this is an electrical problem or not, my igniton doesnt seem to stay on when I turn it to the 3rd positionthe car starts then it returns to the 2nd position and the engine shuts off,I replaced the igniton cylinder, but the car does the same thing with the new cylinder,Im now useing a monkey wrench to hold the key in the 3rd position so i can drive
Old Dec 5, 2005
MegaHurtz's Avatar
WTF dude that's definitely not a good idea, you need to take your car to a mechanic
Old Dec 5, 2005
eye_see_you's Avatar
let the devil out
something is broke..
Old Dec 5, 2005
Al Gore FTW's Avatar
jdmtytedoridori
probably something with the mechanism in there
Old Dec 5, 2005
Steven 89's Avatar
Cool Man"DUH"glo
thankyou thankyou,you really think somethings broke huh,Well no shizzle captain obvious
Old Dec 6, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
doesnt that keep the starter engaged? You could always use a manual switch to power up the ignition wires. You'll still need the key to allow the immobilizer to disengage.
Old Dec 6, 2005
tbaleno's Avatar
tbaleno is an unknown quantity at this point
Either the ignition switch is broken or there is in open in your ignition wire somewhere. That would be my buess. Did you recently hook anything up to the ignition wire?
Also, maybe someone else knows, is there an ignition wire fuse that could be blown?
Old Dec 6, 2005
not a fuse issue, he can drive if he holds it in the start position, so something internal isnt keeping the ignition line powered up.
Old Dec 6, 2005
jdmtytedoridori
ICU said that something's broken, noob.
STP03BlueSI
Florida
Jul 28, 2006 12:35 AM
fivespeed
May 29, 2006 02:24 AM
