on off switch
Old Dec 5, 2005
dope_99's Avatar
dope_99 is an unknown quantity at this point
on off switch
i need help wiring an on/off switch for my amp i want to use my 12v constant but i have a green light and a red light i want the green light to be on when my amps on and the red for when its off please help thanks
Old Dec 5, 2005
05reverb's Avatar
05reverb is an unknown quantity at this point
your switch has 2 lights? more info, how many pins are on your switch and does it mark wich pins are what?
Old Dec 5, 2005
dope_99's Avatar
it has 3 pins and there not marked its the only switch i could find that fits in the spot i have
Old Dec 5, 2005
05reverb's Avatar
u sure there is 2 lights on your switch? anyways one of the pin is for your constant 12v, 2nd is for the wire going to your amp (remote) and the 3rd is for ground. but since there not marked, if you put the ground wire at the wrong place, you will short your 12v constant. you should use a multimeter to check how the switch works. Where you getting your constant 12v from?
Old Dec 5, 2005
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
Amp Turn On Led Indicator Diy
Wait wait wait, you I hope you mean you have a switch, a red LED with resistor, and a green LED with resistor. and you want to hook the switch up to the remote wire, where the led will light green when you have the switch on and the amp is on, and the led will light red with you have the switch off when the amp is off. Follow me?
If that is it well this DIY is for you.
You need a Single Pole Double Throw relay.
You connect the remote wire output [HU side] to the #30 common terminal,
You connect the other half of the remote wire [amp side] and connect it to the #87 NO terminal
You connect a ground to the #85 terminal
You connect any +12v but use an inline on/off rocker switch to interupt the flow
finally are the LED portion
the #87a NC terminal will connect to the red LED with an inline resistor then from the resistor to a ground
the #87 NO terminal will have the the amp side of the remote wire attached, now you tap off that wire, with the green LED with an inline resistor then to a ground
like stated before this will make the red LED illuminate when the remote wire signal is interupted by the switch and the green LED will illuminate when the amp is on
NOTES: *important
1. 85 and 86 can be reversed but it is a good practice to put the ground on the 85 and the positive source on the 86, this is to get a good habit incase you ever incounter a relay with a internal spike supression diode
2. the +12v for terminal 86 can either use a constant, ignition, or accessory +12v feed
*3. Make sure you tap off the wire on the 87 NO terminal, you cannot run the LED in series with the remote wire
*4. Make sure you use resistors inline with your LEDs use anywhere from 330 ohm to 1K ohm 1/2 watt 5%tol. - 330 will be bright - 1k will be dimmer,
To properly wire an LED I will link a page that explains it, props all to the site on this one, I've bought from them and it's good stuff: http://www.oznium.com/led
ok, ok, with this set up the LEDs will illuminate when the radio is on, if you want them always on you have to wire it differently
UPDATE:
The wires can be changed with between terminals #86 and #30 common, if you do that a light will always be on, but LEDs do not draw that much power anyways. And so if you do that the switch is optional [still before terminal #86 if used]
lastly here is a quick diagram I drew up:
Old Dec 5, 2005
dope_99's Avatar
thanks for the fast reply thats exactly what i want but im lost on how you did that
Old Dec 5, 2005
diskreet's Avatar
thank god there are other nerdy people who understand electronics.
Old Dec 5, 2005
I just thought it up, been studying for my MECP test. What part are you lost on?
Old Dec 6, 2005
dope_99's Avatar
i dont really want to splice into my fuse panel but if i have to i need it explained a little better im stupid with electronics
Old Dec 6, 2005
No need to tap fuse box, all the wires you need can be found in your radio's harness.
Yellow is constant +12v
Blue [or blue w/white line] is your remote wire
Red is a ingnition +12v
Black is ground
Old Dec 6, 2005
dope_99's Avatar
can you explain how to do it using the radion harness make it idoit proof for me
Old Dec 6, 2005
Which one do you want, so it lights up all the time or just when the radio is on?
Old Dec 7, 2005
dope_99's Avatar
leds
i want just the red light on when i turn the amp off and i want just the green light on when the amps on
Old Dec 7, 2005
Pull out your radio-
1. Attach the yellow wire to the switch, then connect the switch to terminal 86.
2. Attach a wire to ground, [or the black wire, which is a ground] then attach it to terminal 85.
3. Take the blue remote wire, cut it attach the side going to the radio to terminal 30.
4. Take the remote wire side that runs to the amp and attach it to terminal 87.
5. Take the red LED with a resistor attached in line and attach it to terminal 87a then ground the other side of the LED.
6. Tap into the wire comming off of terminal 87 [and running to the amp] and attach the green LED with a resistor attached in line and ground the other side of the LED.
-put radio back in.
Old Dec 7, 2005
chaoticmav's Avatar
chaoticmav should not be trustedchaoticmav should not be trustedchaoticmav should not be trustedchaoticmav should not be trusted
Man + for you...
Just because you know exactly what the hell you are talking about and I got lost at the picture...
Old Dec 8, 2005
dope_99's Avatar
terminals
im lost on the whole terminal thing is this suspose to be the fuse box
Old Dec 8, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
hes talking about the terminals on the relay. It sounds like your going to need to find somebody close to you with some electrical knowledge, or just a good supply of fuses.
Old Dec 9, 2005
Buy a relay and it will help you see what the picture represents.
robjcivic
Mar 12, 2017 12:10 PM
MamaBear2015
49
Sep 29, 2015 01:12 PM
Klame9420
Sep 7, 2015 10:03 PM
junkyardguy
Sep 2, 2015 06:07 PM
