How to check an amp??
Old Nov 23, 2005
manthatguysfast's Avatar
How many pots have you smoken?
manthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of light
Whats up..
I have a Kenwood amp that I thought went out because the speakers it was running stopped working. i ended up getting an infinity amp to replace it...and when i hooked it up, the speaker problem still persisted. anyways...we took care of the problem and i kept the new amp...but im not sure if the Kenwood was part of the problem to begin with..
how can i check to see if its in working condition without putting it in my car???
Old Nov 23, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
how about a little more info... any red lights on the amp? Were the speakers blown? Wiring bad at all? was the amp getting voltage? We're not clairvoyant
Old Nov 23, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
go to walmart or any auto store and ask for a voltometer. go get one and test the amp. instructions included when you buy it. it will let you test speakers, subs, and amps.
Old Nov 23, 2005
uhmm..im really not exactly sure what the fock was wrong with my speakers. ok it was like this...
I got a new deck...2 days later my front speakers (components) started cutting in and out. they were powered by the kenwood amp.
took it to a audio guy - said my amp was bad.
bought new infinity amp - components started working with new amp - then after about 15 minutes started cutting in and out again.
took it back to the audio guy...he wasn't sure wtf was wrong...he switched (either switched, or just unplugg/plugged, i cant remember) my L/R inputs just by chance and everything was fine.
so i just left the new infinity amp hooked up and now i have the kenwood just sitting in my closet. i was thinking i could sell it, but i wanna make sure its in working order...cuz im pretty sure it was never a problem with the amp to begin with.
so if its working...the voltometer should just show that its being powered. or, could something be wrong even if its getting power?
Old Nov 23, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
you need to hook it up to a 12 volt power supply, if it turns on, connect an audio source to it and a speaker to the output side, if you get music, your all good. Best buy will bench test your equipment for you. If their not busy probably wont charge you that much for it
Old Nov 23, 2005
best buy, eh? i'll probably go that route, less hassle. haha.
hey...i tried to give you rep cuz youve helped me quite a few times in the past..but it says ive already given you rep for this post.. i dunno, but thanks a lot for your help
Old Nov 23, 2005
no problem, glad to help
HX
Dec 28, 2001 10:04 AM
Micks2K1
Dec 6, 2001 07:09 PM
delacampos
Nov 7, 2001 09:18 PM
dubbc
Nov 7, 2001 02:24 PM
GoofyLogicInc
Oct 25, 2001 09:50 PM
