Where can I buy a tool that...
Old Nov 22, 2005
MegaHurtz's Avatar
Strips a piece out of a wire so another wire can be soldered onto it? If I wanted to say, tape into a wire in my car for example. I'm trying to find something that can do this automatically, like I put the wire inside of it, pull the handle and BAM wire gets stripped.
Old Nov 22, 2005
02silverbullet's Avatar
02silverbullet is an unknown quantity at this point
do you mean like a wire-stripper? they sell those at any home depot or other tool shops
Old Nov 22, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
http://www.tigerdirect.com/applicati...sku=C184-38007
Old Nov 22, 2005
pon55's Avatar
What you are looking for is available from American Beauty company! It will remove a piece of insulation off a wire so you can solder in a tap.
The only problem is the last time I checked it was about $900
Old Nov 22, 2005
disturbed24st's Avatar
disturbed24st is an unknown quantity at this point
What you need is a tap its a plastic piece with metal on the inside.When you close it down on a wire the metal cuts through the insulation on the wire.The metal makes connection with the wire.then you just put a terminal on the other wire and plug it into the tap.Any auto parts store sells the taps and terminals together in a package.It works great and holds very tight much easier than trying to strip a spot off the wire and solder it.
Old Nov 22, 2005
pon55's Avatar
Thats what I use, but most peps don't like em!
Old Nov 22, 2005
I'm an electrician.I use em all the time.
Old Nov 22, 2005
nick95673's Avatar
if megahurtz the audio mod doesnt know what t-taps i will be very surprised. i think he wants a wire stripper that strips wires in the middle not at the end. he also wants it to only strip half the wire so there is the minimum amount of insulation lost in the process. i say buy a sharp *** pocket knife. or the 100 pack of razor blades.
Old Nov 22, 2005
pon55's Avatar
Not Code!
Old Nov 22, 2005
pon55's Avatar
I have yet to find anyone able to strip insulation with a blade and do it right!
Old Nov 22, 2005
nick95673's Avatar
thats why he would want the tool!
Old Nov 22, 2005
The kind of work I do I don't have to follow code.
Old Nov 22, 2005
MegaHurtz's Avatar
Yeah I know what taps are. Believe it or not I've actually wired electrical systems before
Yes I am looking for a tool that will strip a piece of insulation from the middle of a wire, exposing the copper. Yes i own several drawers full of taps, t-taps, connectors, and everything else under the sun, but that wasn't what I was looking for now, was it?
Old Nov 22, 2005
pon55's Avatar
Old Nov 22, 2005
blackdragon's Avatar
blackdragon will become famous soon enoughblackdragon will become famous soon enough
http://www.newegg.com/Product/Produc...82E16899888402
Old Nov 22, 2005
pon55's Avatar
Should I,Should I,Should I,Should I,Should I,Should I,
A cig lighter would work!
Old Nov 22, 2005
pon55's Avatar
WOW- WRONG
Old Nov 22, 2005
nick95673's Avatar
oh yes the famous cig lighter trick. the one we picked up from crazy cousin ken who is always walking everywhere. i figure you do crank for suggesting that idea.
Old Nov 22, 2005
pon55's Avatar
Hey, you know my cousin ken?
Old Nov 22, 2005
http://www.controlcable.com/details/item.asp?id=43332380|70500|
Old Nov 22, 2005
nick95673's Avatar
http://www.specialized.net/ecommerce...t%5Fid=024X026
http://www.action-electronics.com/strippers.htm
Old Nov 22, 2005
nick95673's Avatar
so i called my dad. he has worked at intel as an electrical engineer for 23 years. He does actually build test equipment he doesnt just do math and run tests he builds a lot of electronics ranging from very small to stuff the size of a fridge. He was still at work where he asked 6 engineers with a combined total of 126 years of working with very expensive wire tools and they have never heard of what you want. they suggest a knife or razor blade. I didnt give up so i called an aerojet rocket scientist. thats right a rocket scientist the freakin gold standard for knowing answers. his response was "use a knife"
Old Nov 22, 2005
evilone's Avatar
The Nightraid crew - Sensible Ownage
evilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the rough
Me personally....I use a utility knife with a carpet blade. No worries about hacking your finger in half, and you still get the job done cleanly.
Old Nov 23, 2005
AlpineCivic's Avatar
I know what your looking for, and let me tell you they are not ideal for the car inviroment. The stripper your looking for is big and bulky and is very har to get into those tight places in the car.
Use a regular stripper, just make 2 cuts where you want to solder, pull the insulation off and there you go. you now have a clean place to solder.
Old Nov 23, 2005
Here maybe this is what your looking for:
http://www.dlcparts.com/frontend/pro...R+TOOL&ID=1143
Old Nov 23, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
that what i usually do, if im feeling crafty I'll take an old soldering iron, heat the insulation till it melts and then pull it off with a pair of pliers, strips it perfectly without knicking the wire
Old Nov 23, 2005
pon55's Avatar
That is basically what the American beauty tool does.
Old Nov 23, 2005
05reverb's Avatar
05reverb is an unknown quantity at this point
I'm an electrician and we sometimes do that. What we do is take our wire strippers and make a cut in the insulation and do like you want to strip it just a little bit, then go to (watever lenght you want to have of stripped wire) and make another cut and move the insulation back towards the other cut. Now that small piece is loose, so you then take an ELECTRICIAN KNIFE and slide it across to remove that piece. The reason i said electrician knife, is because they are not too sharp, if you use a regular blade knife, it will probably cut into the copper wire. As for tools, i'm not aware that they make any.
Old Nov 23, 2005
^^thats what I said but in less detail.
Old Nov 25, 2005
tbaleno's Avatar
tbaleno is an unknown quantity at this point
A punch down tool? How would you use one of those in this situation? He isn't installing phones
I think razor blade and heat shrink tubing is the best compromise between money spend and quality of workmanship.
