Amplified antenna with Headunit PLS ASSIST
Old Oct 17, 2005
cwo715's Avatar
Falken Master
cwo715 is just really nicecwo715 is just really nicecwo715 is just really nicecwo715 is just really nice
I was told by Honda, that if i put in my Kenwood headunit that i will need to purchase an aftermarket amplifier for the Antenna. I have an 05 EX MTX.
Pls. Assist
Anyone know if thats true, and if so where can i pick one up. i was told by him it was like 6bucks
Old Oct 17, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
you dont need it, just make sure the power antenna wire on the car side of the harness is hooked up to your aftermarket receiver. We dont have a power antenna, but their is a antenna booster built into the car that needs to be turned on when listening to the radio.
Old Oct 17, 2005
cwo715's Avatar
Falken Master
yea thats what i meant, do we have to buy the antenna booster for it?
Old Oct 17, 2005
nope
Old Oct 17, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
No, the wire is already there and there's one on the harness. Just make sure to hook it up.
Old Oct 17, 2005
05reverb's Avatar
05reverb is an unknown quantity at this point
The booster is already in the car, just connect the power antena wire from the car harness to the blue wire on the kenwood deck.
Old Oct 17, 2005
20civic01's Avatar
20civic01 is an unknown quantity at this point
don't mean to jack the thread, but is there an easy way to connect this wire, or do i have to take apart the dash? i had a hu replaced by insurance, and i don't think they did this. (i have an alpine 9835)
Old Oct 17, 2005
05reverb's Avatar
only if they installed your HU with the sleeve, in that case, just slip out the HU and make the connections, but if it's bolted on the sides, you'll have to take it apart, but it's not a big job to get to our HU's
Old Oct 17, 2005
20civic01's Avatar
does that mean i pry off the plastic piece that runs around the edge of the headunit and try to slide it out?
Old Oct 17, 2005
05reverb's Avatar
the sleeve is the aluminum sleeve that comes with your HU. If they installed your HU with that sleeve, you can use 2 small pieces of metal (one each side of the HU) to unlock the sleeve and slide it out.
Old Oct 17, 2005
MegaHurtz's Avatar
since when do those sleeves fit in our dash opening?
Old Oct 17, 2005
05reverb's Avatar
I don't know if they fit, I never installed a HU with those sleeves, I always bolt The HU on the sides, I just know some people use those sleeves I didn't know it didn't fit in certain cars. I never figured out how to attach those sleeves in the dash so I always bolted it instead.
Old Oct 18, 2005
your talking about the alpine sleeve with the little fingers. Its a cool design, i installed one in an 04 tonight at work, it woulda held but I bent some tabs just to be sure.
Old Oct 19, 2005
4Saris's Avatar
4Saris is an unknown quantity at this point
If the harness did not come with a blue wire connection, what do I connect it to? I think I did the green/yellow wire in my 01, but I can't remember for my 03. Thanks.
Old Oct 19, 2005
i used the alpine metal sleeve, it fit fine in the dash piece. if you don't connect the wire, you will know for sure cause there will be tons of static. otherwise alpine tuners are really good quality.
