Please Help !!
Old Oct 16, 2005
smalie25's Avatar
New Member
smalie25 is an unknown quantity at this point
Arrow Please Help !!
My English is poor because I am from PUERTO RICO mainly speak ang write SPANISH. I cant seem to Find any information on how to get wiring from gauges mounted on pillar from my pillar firewall out to my front right headlight or engine bay. I've search for two days and havent found anything. Its a 2005 CIVIC
Old Oct 16, 2005
ajhdragon's Avatar
7thgens official a$$hole
take out your glove box and then remove your ECU, their is a rubber thing in your firewall, you can poke a hole in that and run the wires through there.
Old Oct 16, 2005
smalie25's Avatar
New Member
That was good information... but wires go down drivers side Pillar how do I get them over too glove box ??
Old Oct 16, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
you can just drill a small hole in the firewall to pass the wires through. Just make sure to check the other side before drilling.
Old Oct 16, 2005
Diablo's Avatar
Diablo is an unknown quantity at this point
look in your engine bay fire wall on the passenger side you should see were the wiring harness runs from your engine to the interios poke a hole in the ruber run your wire threw there.
Old Oct 16, 2005
smalie25's Avatar
New Member
Are you serious ?? I have till Mañana for this...
Old Oct 16, 2005
smalie25's Avatar
New Member
I understood the Passenger side wiring . Just looking for a Way to Get wires thru without drilling. Remember this wiring goes down Drivers side Pillar firewall
Old Oct 16, 2005
Diablo's Avatar
you can fid a way to hide it under the dash across to the passenger side. what exactly are you trying to do? write it in spanish if it makes it easier
Old Oct 16, 2005
just look near the brake pedal under the driver side. there should be a rubber boot that pops off and reveals a hole. you will prolly have to drill it tho unless you've had an alarm installed and they already did it for you.
Old Oct 16, 2005
Diablo's Avatar
you should not have to drill. i ran my tack wire threw the rubber plug on the fire wall by poking a hole with a hanger
Old Oct 16, 2005
Diablo's Avatar
go threw this pictures on thid diy you will se how this guy ran his wires on the second pic thats how you can run you wires
http://www.7thgencivic.com/forums/sh...d.php?t=155267
Old Oct 16, 2005
smalie25's Avatar
New Member
Thanks for these two options both Daiblo and Gearbox have given me !! Found both of them .
Old Oct 17, 2005
smalie25's Avatar
New Member
Thumbs up Its done !!
This is what I did ...
1. Found hole with rubber fitting right below Hood Cable inside 2005 Civic.
2. Took Tach signal wire along hood cable(very well hidden cable) behide Right fender plastic cover and secured it along there.
Old Oct 17, 2005
nice job
