teach me how to set the crossovers on an amp
i'm basically asking if you could help me figure out how to set up the crossover on an amp... explain to me what frequency would do what if the amp is hooked up to fronts and rears and a sub... kinda hard to figure out what i'm saying?? i don't blame you... but thanks anyways
The Standard One
try this link... http://www.crutchfield.com/infolib/S...x.asp?id=xover
all i have is subs so i just tweaked the setting to whatever sounded best
Depending on your freq. on your amp, your fronts will want to be set at a higher frequency of course. Does your amp have a couple of settings or can you roll through an entire range? Basically what I would do is sit in the car and have a friend start adhusting the frequency until you get a nice medium of bass and treble without any distortion. You will probally have to play with it for a while to get it the way you like it at both high and low volume settings.
The Standard One
oh hold up your using the crossover on your amp for all speakers? does the amp have 3 different crossovers? most likely it doesnt so ya i suggest you get a seperate crossover...
thaler4cuse
Sep 7, 2015 08:25 PM
redcloud
Sep 7, 2015 01:45 PM
wingsfan19
15
Sep 2, 2015 02:15 AM
redcloud
25
Aug 12, 2015 01:23 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
