My amps keep going into protection. Why?
Old Oct 9, 2005
hondmatic's Avatar
hondmatic is an unknown quantity at this point
Thumbs down My amps keep going into protection. Why?
I can't seem to figure it out. Whenever I have both my amps for my subwoofer and highs hooked up, they'll both go into protection mode and shut down. And it usually takes like a day for them to turn back on. If I have just my amp for my highs hooked up, nothing happens. My system works fine...minus the sub. So i'm thinkin it has something to do with my amp or sub. I have 0 gauge power wire. Jbl BP1200.1 to my 12" RE Audio XXX. Some Audiobahn amp for my highs. Highs= RE Audio components. I have a capacitor for my sub. Stinger SPV35 battery. And a circuit breaker up front. Any ideas on what it could be? I'm thinkin the 0 gauge wire takes too much power from my battery and the alternator can't keep up...but idk. Could it be my amp is faulty? Any help is appreciated. Thanx.
Old Oct 9, 2005
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
did you start to tune the sub amp with the input voltage all the way down, then turn it up slowly, i started mine at 3/4 the way up and it was drawing too much power and going into protection because my voltage would drop like crazy, but when that happens it should turn back on right away
pm me with details
Old Oct 9, 2005
MegaHurtz's Avatar
sounds like it's probably a setup problem, check your amp settings and go from there.
Old Oct 9, 2005
hondmatic's Avatar
Should I turn the gains, bass boost, voltage all the way down and go from there?
Old Oct 11, 2005
0260n4's Avatar
0260n4 is an unknown quantity at this point
To much power! Shorting out...Maybe a crossover issue. Does it cut off right away, or does it over heat first?
Old Oct 11, 2005
yea, did you try it yet?
Old Oct 11, 2005
jay78's Avatar
jay78 is on a distinguished road
mostlikely..when this happnes...because not enought power or wireing problem..
does your emp shutdown when u your vol is high?
or even with low vol ???
if it does only at high vol then need upgrade your power...extra bet or something....let me know....
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
