Amp recommendations?
Old Sep 25, 2005
dacali's Avatar
dacali is an unknown quantity at this point
I was considering getting an amp for my speakers. I have a set of Infinity Reference 6000cs up front (4 Ohm, 2-90W RMS) and Alpine SPS-690A in back (4 Ohm, 2-50W RMS). What brands would you recommend? Should I go with a 4-channel amp or 2 2-channel amp? Thanks in advance!
-Dacali
Old Sep 25, 2005
ruckerheadz's Avatar
ruckerheadz is an unknown quantity at this point
u want a good 4channel amp and u dont wanna run it lower than 4ohm with components to keep a good sq with them. for brands heres a list of awsome companies. milbert, butler, tru, genesis, us amps, zapco,audison, brax, mcintosh anything from stephen mantz www.zedaudio.com. hope that helps a lil u cant go wrong with any of those amps, but quality aint cheap so dont except to find a good one less than 400bux used
Old Sep 29, 2005
RS4DUKE's Avatar
RS4DUKE is an unknown quantity at this point
i prefer mtx amps for components and speakers, they are not to great for subs for the mtx thunder series is known for clarity, you should be able to find a good quality 4 channel for around 300 bucks.
Old Oct 1, 2005
soltex's Avatar
soltex has a little shameless behaviour in the past
check this site out they got stuff for cheap. i got an kenwood 1800wat amp for 189
http://www.sonicelectronix.com/
Old Oct 1, 2005
chriscivic's Avatar
chriscivic is an unknown quantity at this point
get an avionnix 440.4 , 85x4 rms at 4 ohms, i am running that with alpine type r front and rear speakers. sounds great, you can check ebay or they go for liek 130 shipped used on sounddomain
Old Oct 1, 2005
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
Alpine amps are well built with clean QUIET power.
Old Oct 3, 2005
dacali's Avatar
Thanks for the replies! Unfortunately, it came a little late as I've already ended up buying.
I ended up going with an Alpine MRP-F240 (40W x 4 or 100W x 2, both @ 4 Ohm) from ikesound.com and a 4-channel amp wiring kit from Knu Konceptz. I'll use it as a 4 channel until I can get an MRP-T220 (50W x 2 @ 4 Ohm). Then I'll use the MRP-F240 for the fronts and the MRP-T220 for the rears. Not sure if that's the best use of money, but that's what I bought.
*starts waiting for amp and wiring kit to come in*
-Dacali
h4ldol
Apr 24, 2017 08:16 PM
twd000
Oct 4, 2015 12:52 PM
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
