Huge problem with vafc2! Need help asap!
Old Sep 18, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
ok... we got it all hooked up, but no display on the screen. What could be the problem. We used wire taps instead of solder or anything like that. Got any idea's? I bought it off madwheel who works for dezod, so it shouldn't be bad.
Old Sep 18, 2005
kileryoyo's Avatar
kileryoyo is an unknown quantity at this point
Maybe using the wire taps it has not made a complete enough connection.
Old Sep 18, 2005
Blahman240's Avatar
Thought about that.,. hmm, we checked them, and they all seem ok.
Old Sep 18, 2005
um mine works fine with taps. check your connections. Did you use the diy?
Old Sep 18, 2005
Blahman240's Avatar
yea, used the diy, No go.
Old Sep 18, 2005
cwick187's Avatar
cwick187 is an unknown quantity at this point
When I installed mine with wire taps, I noticed that the power would go in and out, because of a bad connection...I went and just soldered it like it suggested in the manual...Make sure your ground is connected...The VAFC is super picky with the grounds, or you could just have a bad unit..
Old Sep 18, 2005
Blahman240's Avatar
It worked for mad wheel, I didn't use diodes could that be why?
Old Sep 18, 2005
vafcii doesn't need diodes. i'm sure you just wired it wrong or the unit is bad
Old Sep 18, 2005
Blahman240's Avatar
hopefully its just the wires. I think we're gonna end up soldering.
vmunoz
May 30, 2015 09:31 PM
usajags84
May 30, 2015 06:49 PM
