Is there any reason to get a 5-channel amp over a 4-channel?
I am looking at this amp. It seems to have a lot of good reviews and looks to be right around what I want power-wise. I don't have a sub now, and am not sure I ever will, but if I ever get one, it would probably be only a single 10". For only $40 more, I can get this amp. My concern is that the 5th channel on that amp is only 160w @ 4ohm. My understanding is that is not really enough to push a sub. What do you all think? Go for the 5-channel or save the money and pick up the 4-channel?
Brian
Brian
Only reason would be for convenience.. the sub channel wouldn't really have that much power at all. Enough to power a single 12 well enough bump..but not enough to boom [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Cheers
Mohawk
Cheers
Mohawk
End Bringer
with 4 channel, u can hook up 2 channel to the interior, and then the other 2 bridge into ur sub, with 5 channel.. it's kinda hard, lightning audio does offer a 7 channel amp, which would be more convient then a 5 channel
Well, I ended up getting an Eclipse 36401 instead. It was a better amp (on paper at least) than the Alpine and it ended up being about $75 cheaper after install. I bought the Eclipse solely on the recommendation of the car stereo guy since I hadn't read anything about it. Hopefully I made the right choice.
Thanks for your help guys.
Brian
Brian
