troubleshoot JL amp 1000/1
Old Sep 9, 2005
jayjdlc's Avatar
jayjdlc is an unknown quantity at this point
hi! i was fixing the installation of my sound system setup cause the guy that installed it was an ***----. when i was finished redoing the HU installation, i went in the trunk because there were no sound coming out of my speakers. I found out that my JL amp 1000/1, JL amp 300/4 and crossover does have any power. i dont know if this will help but theres a power on my capacitor. does anybody know what happened on my set up? help me. thanks!
Old Sep 9, 2005
MegaHurtz's Avatar
take it back to an installer and get him to fix it for you
Old Sep 9, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
So you've got power up to the capacitor? I didn't understand that part as the wording was tricky. If this is the case, test the wire coming off the cap and see if it has power. Or, remove the cap adn hook everything up. If it works, it's a problem with teh cap. Try checking all your connections to make sure nothing is lose, or broken.
Old Sep 9, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
yea. if u got power to the cap why dont u test to see if u have power coming from the cap????..
Old Sep 11, 2005
slick's Avatar
that little dude
slick will become famous soon enoughslick will become famous soon enough
Digital multimeter is your friend.
Did you connect your remote turn on? Try switching the amps to auto turn on or whatever, see if anything happens then.
Old Sep 11, 2005
spoonEM's Avatar
omgwtfbbq mod.
check your remote line.....thats probably your problem. You may have forgotten to hook it up when you did your HU. And if it is hooked up.....get a voltmeter to make sure its good. A while ago I bought a head unit....and for some reason....the remote wire was the only wire not getting volts. So i sent it back...got a new one..and it worked. Also....some HU's have 2 wires that look the same. One is the remote...the other is usually power antenna. (for cars that have it)...this wire is usually blue with a white tracer. I dunno what HU you have.....but check the manual it came with and it will have what wires are what just to double check. If none of that works....take it back to the jackass that installed it. Or....if that doesnt work...just give me your amps. lol
Old Sep 12, 2005
jay78's Avatar
jay78 is on a distinguished road
as he said....make sure the remote wire is connected........thats the most common error
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
JetsterDajet
52
May 8, 2016 12:11 AM
Luluharp
Sep 27, 2015 11:56 AM
Mc7602
Sep 17, 2015 02:01 PM
