How can I test my AMP to check if it working?
Old Aug 28, 2005
Amer786's Avatar
Senior Member
Amer786 is an unknown quantity at this point
MTX 8302. It is not installed in my car, it was pulled out of my other car, but it was not working at the time. I want to now try and diagnose weather it is the amp or just wire connections in the old car that was the cause of it not working. Is there a way to do this? I have power wire coming from the amp and a ground. The red light on the amp does not com on
Thanks for your help
Old Aug 28, 2005
05reverb's Avatar
05reverb is an unknown quantity at this point
the red light's not coming on because you need the remote wire to turn it on, when you have the power and ground connected to the battery, take a wire and put it in the remote on your amp and touch it on your + wire to turn it on.
Old Aug 28, 2005
Amer786's Avatar
Senior Member
So I can connect the power directly to the battery without risk of damage to the car or amp? The amp used to work, there was sound coming out of the sub I was using, then it just stopped working, so it may not be a remote wire issue unless it was connected and somehow was disconnected
Old Aug 28, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
the simple way to test it is to simply take 1 wire and hook it up to the power terminal then jump it over to the remote terminal then run the wire to the +bat. terminal then run a piece of wire from the -terminal on the amp to any ground. you can use speaker wire for this it doesnt need to be 8awg. but all this will tell you is if it turns on. if you want to see if it will play then you would need to run rca's from some kind of source like bring a ps2 out to your garage and use that as a source then hook up an old 6-1/2 and see if it plays. once again this wont tell you if its perfect it will only tell you it will power a 6-1/2. typically this is the equivalent to anything a car audio shop will do to test your amp.
Old Aug 28, 2005
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
you could always just use a meter reader to see if its getting power.
injen
Old Aug 28, 2005
Amer786's Avatar
Senior Member
So 1 wire from power terminal to remote terminal
Another wire from remote terminal to + bat terminal
Another wire from neg terminal on the amp to ground on the car
I just was not sure of what you meant by "jump it over to the remote terminal"
Old Aug 28, 2005
nick95673's Avatar
yes exactly. what i meant by jump it over i would need a pic to describe.
Old Aug 29, 2005
Amer786's Avatar
Senior Member
so all i need is the 3 wires, i guess i can ignore "Jump it over". sorry just trying tomake sure i dont blow anything
roverben
Jan 21, 2019 05:16 PM
ORskier
May 3, 2015 12:54 PM
delacampos
Nov 7, 2001 09:18 PM
dubbc
Nov 7, 2001 02:24 PM
GoofyLogicInc
Oct 25, 2001 09:50 PM
