I have a question about my bass?
Old Aug 10, 2005
blackdog's Avatar
blackdog is an unknown quantity at this point
So I have two MTX 10s in my trunk pushed by a quantum 1000watt amp and a panansonic cd player. My question to you is...how do I get the tight quick thump kind of bass out of my speakers. I listen to rock and I like to feel the bass drum thumpin at my back. Do I turn the bass on the amp up and the bass on the cd player down...seems like I have heard that somewhere before..i dont know though. Please help, and thank you to everyone that does. PEACE.
Old Aug 11, 2005
01redJDM's Avatar
01redJDM is on a distinguished road
If u want more bass on ur speakers, turn the bass on the deck up and turn sub out put on the deck down, if u want more bass on ur subs, do the reverse + turn the bass on the amp up
Old Aug 11, 2005
R1Style's Avatar
What kind of box do you have your subs in? If you want a quick punching sub then you need to put it into a smaller sealed box.
Old Aug 11, 2005
blackdog's Avatar
there in a pretty big box actually, its a ported box with the space between
Old Aug 11, 2005
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
like r1style said, you need a sealed box. also, you might want an equalizer for some tuning to get it to sound more like you want it. good luck.
Old Aug 11, 2005
MegaHurtz's Avatar
work on your box, don't bother messing with the controls they will just make it sound awful
Old Aug 11, 2005
blackdog's Avatar
so how much will i be looking at spending for a new box and to put my speakers in it? I didn't think that the box had anything to do with how they sounded...i mean it all sounds real good now, i would just rather the bass drum be bolder and stand out a little bit more, i have a friend with an integra and his sounds really good. but now that i think about it his box is closed in and smaller than mine...makes scense now.
Old Aug 11, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
i built the one in the diy section from around $60, look up the model numbers on the subs and see what the volume needs to be for each sub in a sealed box and when u build the box, u'll need a baffel (a divider) so each sub has it's own enclosure
Old Aug 11, 2005
82801BA's Avatar
82801BA is an unknown quantity at this point
It's like drum punching your back, right? Understandable, lower sub freq about 80Hz by 0.5 Q at -6dB and you will have a better chance of having a drum as a thump instead of a bump hitting your back bone....My own experience, don't know if it works out for you...
Old Aug 12, 2005
blackdog's Avatar
yeh, ill try to fiddle around with some controls again, and then see about getting a new box if that doesn't work out for me
thanks everyone
Old Aug 13, 2005
drew22mader's Avatar
There is gl@ss in my @SS...
W/E you do don't mess with the gain on the amps, don't turn them up they will ruin your stuff. What you need to do is get a sealed box and you can put stuffing in it or take out according to your sound preferences. EQ's will also help you tune everything to your liking.
JMKendrick
Sep 16, 2015 06:17 PM
junkyardguy
Sep 2, 2015 06:07 PM
Deeup511
Aug 30, 2015 04:48 AM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
