Help Me Please
Old Jul 31, 2005
qik1's Avatar
qik1 is an unknown quantity at this point
Help Me Please
i have an 05 civic ex sedan i'm trying to find out what i can run my remote wire to. i don't want to run it to the head unit since i don't have to go back there for anything else since i have a stock head unit i also have the converter box i'm gonna jump them to the rear speakers and mount the box on my sub box.
Old Jul 31, 2005
jgrow44's Avatar
jgrow44 is an unknown quantity at this point
run it to the fuse box with a toggle switch. that way you can turn off you subs if you want.
Old Jul 31, 2005
qik1's Avatar
do have to have a toogle switch
Old Jul 31, 2005
qik1's Avatar
which fuse box which fuse
Old Jul 31, 2005
jgrow44's Avatar
under the dash. there should be one for the radio.
Old Jul 31, 2005
Rennen's Avatar
New Mod on the Block
the fuse box right under the steering wheel. connect it to the head unit fuse. no, you dont need to use a switch.
Old Jul 31, 2005
qik1's Avatar
i just fray the wire and stick it in with the fuse
Old Jul 31, 2005
jgrow44's Avatar
i only suggested the switch in case you wanted to turn off your subs for one reason or another. i turn mine off sometimes when i don't feel like lots of bass. you don't have to have it.
Old Jul 31, 2005
Falcon's Avatar
Falcon is an unknown quantity at this point
yeah, you can just fray the wire and jam it in there... just remember that if sometime in the future your subs just stop for seeminly no reason, that is 90% probably the reason
Old Jul 31, 2005
qik1's Avatar
hey guys thanks alot i did what you said took about 2.5 hours i now got beats. nothing nice but i did it so i'm proud of my lighting auido strikes they hit pretty hard i wired my remote wire to fuse 15 under the dash which is the radio fuse i need dyno mat bad i had to turn down the base and all this forum is the best thanks again if you can't tell i'm exited going to get tint next 35% all around.
Old Jul 31, 2005
KnocturnalEM2's Avatar
I am your Mom's Hero!!
Yay another happy modder!! This forum does kick ***!!!!
Old Jul 31, 2005
k20txem2's Avatar
k20txem2 is an unknown quantity at this point
Hope you didnt hook that to a constant fuse, you could burn up your amp if you did.
Old Aug 1, 2005
qik1's Avatar
i hooked it to the remote wire fuse the amp turns off when the key is out or tured to the off position
Old Aug 2, 2005
bluestreak's Avatar
bluestreak is an unknown quantity at this point
i fried my fuseboix somehow doing this. it had been fine for years, unitl now where it's at the dealer
