sound system... SE civic
Old Jul 26, 2005
steven10's Avatar
steven10 is an unknown quantity at this point
who has a SE civic that has done any mods to their sound system? changed speakers?... added amp?.. head unit?... i wanna keep my head unit because i really like the look but the ratings show it sucks really bad but... anyways... list ur mods to ur SE civic
Old Jul 26, 2005
chriscivic's Avatar
chriscivic is an unknown quantity at this point
jl audio came out with a new system that give your stock radio pre outs with excellent sound quality, it was in import tuner
Old Jul 26, 2005
2004_sq_champ's Avatar
2004_sq_champ is an unknown quantity at this point
Its called cleensweep and it is a great product.
Old Jul 26, 2005
interesting. I thought you can also hook up an amp and new speakers to the stock deck? just make sure the amp has speaker level inputs.
Old Jul 26, 2005
jay47's Avatar
jay47 is an unknown quantity at this point
yes u can hook up an amp to the stock deck, but u don't actually hook up the amp to the deck, u hook it up to the speakers. Like^^ said, get an amp with speakers level inputs OR... buy an rca to speakers adapter, not sure of the real name, that will convert the sound waves directed to the speakers into an rca output, usable by all amps. I did this with my system at first but eventually just put in a new cd player.
Old Jul 26, 2005
82801BA's Avatar
82801BA is an unknown quantity at this point
They are called line level converter, but most of them are crap.....
Old Jul 26, 2005
shj503's Avatar
shj503 is an unknown quantity at this point
Can anybody have more info on this??
I'm really interested!
Old Jul 26, 2005
kickercivic1's Avatar
kickercivic1 is an unknown quantity at this point
can you search on google please?
Old Jul 26, 2005
mkymonkey's Avatar
I haven't been here in a long time
mkymonkey is a jewel in the roughmkymonkey is a jewel in the roughmkymonkey is a jewel in the roughmkymonkey is a jewel in the rough
no...not yet, but ill look it up
Old Jul 26, 2005
mkymonkey's Avatar
ok cant find it. plus im lazy.......you can look it up here:
http://www.google.com
Old Jul 26, 2005
shj503's Avatar
I already did, but I just wanted to listen other member's opinion on it
THANKS A LOT
Old Jul 26, 2005
qik1's Avatar
qik1 is an unknown quantity at this point
is the cleansweep out yet and also can you hook your amp up to it if so where i just searched and read on it for about 20mins but didn't see amp imput or any such things
Old Jul 27, 2005
steven10's Avatar
today me and my friend put some sony explodes 240 watt speakers on his car... and wow.. the bass was really nice with the JVC head unit he had... it hits way better than stocks... he had stock front speakers... but it sounded real clean... a little rattle but all around pretty clean.. i was wondering if i changed my rear speakers but kept the SE head unit.. would it hit hard too?
Old Jul 27, 2005
qik1's Avatar
it probably wouldn't hit has hard as his but you should have a night and day sound also thats what i'm doing on the 5th putting in new 6 1/2's and changing tweeters and adding a 800 watt amp to my cheapo lighting audios they hold a pead of 400watts a piece they are cheap but has lasted through 3 cars and they hit harder than the RF punches (proven) rockford actualy makes lighting audio they are knock offs
Old Jul 27, 2005
slick's Avatar
that little dude
slick will become famous soon enoughslick will become famous soon enough
the cleansweep is not just a line output converter, its an equalizer. it automatically flattens the in car response of the system, basically it gives you a flat EQ curve to work with. you're suppose to use an outboard EQ with it, its complicated, and not for the average joe.
if you want to keep the stock unit and use a high quality line output converter, get something from audiocontrol, the LC6 is a great LOC.
Old Jul 27, 2005
82801BA's Avatar
Do you know how hard it is to EQ to a flat (or close to flat) response in our car? You should know better than I do......
Old Jul 27, 2005
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
fromt he other thread you started-
"If you get speakers do not get sony x-plod their stuff is crap, there is better stuff out there for same price. A good set up would be component speakers, 4 channel amp, one 12 inch sub, and mono amp. If you wanna have more bass then you would need two twelves or one 15 and a cap as well.
I have alpine type r components all the way around, with mrv 540 amp, and it sounds amazing. i do not have subs, so i lack real bass cause the typre r are only meant for highs and mids not lows. I might get subs one day, but i woud rather have rims now!
Yes there is a huge difference between your head unit output and an after market one, but it does not matter because if you buy new speaker you will want to get a 4 channel amp, so the HU output does not matter. It would also be wise to get a better HU because if you do not then you will not be using the full potential of your amp/speaker because stock HU does not have RCA outputs.
If all you are worried about is hittin harder, not sound quality, get new HU, mono amp and sub."
Components are speakers with a woofer and separate tweeter that is mounted a couple feet from woofer, sound better. Do not use converts as i have said you will not get all the performance out of amp and speakers, so a new HU is recomended, even with just one sub.
I skimmed throuh your other thread and the clean sweep sounds nice, but you really should invest in a HU with rca outputs.
I would recomend infinity kappa perfects, they re real bassy, my friends got them, sounds like he had subs when he didn't, now he has two of the new type Rs and jsut sounds incredible.
Also man, please do not make two pretty much identical threads, it is a pain in the ****
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Linda0818
Apr 23, 2015 11:30 AM
WhosYoDadday85
Bolt-on Engine Performance
Nov 6, 2001 08:06 AM
01civicboi
Nov 2, 2001 07:33 AM
artychris
Sep 3, 2001 03:39 PM
